20 Most Recent
TruTech T650-DR DVD Recorder Questions & Answers
The recorder's screen is blank
You have developed a power supply problem, to do with the electronics circuitry, the motors supply, is separate. There are no user serviceable parts inside, to even have a shot, you would need a service and repair manual, I have searched, but there is nothing available. You need to get the unit looked at by a TruTech service center,and ask for a "Quote" this way you can decide to repair or replace.
I have tried to load 5 different recordable discs
See if changing recording speed would help. As far as I know the discs should work. Try the discs that you have burned before on another player just to check if there is something wrong with the player.
I accidentaly set my dvd
I think Progressive mode is selected/ activated and causing no video out to your TV, that needs to be deactivated.
Press STOP key on DVD Recorder for 6 seconds to turn progressive Off.
Let me know exact model and brand if problem still unsolved.
Thanks.
How do I record TV
Step 1. Set the recording timer on your DVD recorder to record the chosen program when it comes on, or wait for the show to start and do the recording manually. Place a blank, recordable disc in the tray of your DVD recorder and close the tray.
Step 2. Make notes of where you'd like to insert chapter stops, being ready to skip over commercials and edit them from the program. It helps to have a general idea in advance where to insert chapter breaks. For an hour-long program, chapter breaks every 10 to 15 minutes are convenient when reviewing the program later.
Step 3. Press the "Record" button on the DVD recorder to commence burning the program to DVD. Use the Pause and Edit controls of the DVD recorder to eliminate commercials and create chapter stops on the DVD for easy browsing later. Place the recorded disc in a protective sleeve or case and label it for easy identification later.
Good Luck!!
Thanks
Some dvd's will not read
you just need to clean the lens with cotton or a soft cotton cloth to avoid scratching it..be careful not to touch it with bare hands..
Auto Tuning Problem
Wow sounds like you got a bad box,
Frist your Trutech needs to be set to Ch 3 or 4 what ever is open. if you dont see a Trutech Logo on your TV, then you need to go back to your TV and find the input Ch to your Trutech T650-DR.
If you do see the Trutech Logo then next on your Trutech T650-DR remote keep pressing the source button tell you see A Cable Ch. then press the return button.
Thats It hope I could help.
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
How to burn a dvd from a JVC Hard disk drive recorder
Make sure you plug your camcorder into the in on the dvd recorder. Make sure the dvd recorder is set to that input. you may need to hook it up to a tv and make sure you see your camera on the tv going through the dvd recorded to make sure you have it on the right setting. Make sure you camera has playback out turned on.
Will This DVD Recorder Burn DVDs from a Desktop?
Ive never seen a standalone DVD recorder that can connect to a pc unless it had a Hard Drive. This model is a Target exclusive company. These devices are designed to record video direct from either Antenna,Cable,VCR,or something such as a game console, or camcorder.
Hope this helps!
HELP
There should be no problem with copying home recorded VHS tapes to DVD via the Scart or Video (yellow) output. It may be obvious but have you tried recording directly from other sources such as TV etc. Apologies if this is a trivial suggestion!
Cheers
