20 Most Recent
LG LDF8812 Stainless Steel Built-in Dishwasher Questions & Answers
How to replace door springs
There is a service bulletin on the spring and connector(the cord that connects the spring to the door)The spring for the hinges part number is 4970ED4004G. You will need to change the connector assembly for each hinge (plastic colored black at each end of the cord instead of white) and that part number is 4933DD3001B. I use a heavy coat hanger with a hook bent at the end. At the other end where I hold it, I've bent the remaining length of the hanger into a handle of sorts. This gizmo is about 1.5 feet long. Release as much tension from the springs as possible by closing the door. Using a headlamp, remove the kick panel and locate where the springs are attached to the lower frame. Now, using the coat hanger, hook the end of the spring that is attached to the cord. Pull firmly against the spring tension with one hand and unhook the spring from the cord with the other. Do this on both sides. Reach underneath and remove the springs and replace them with the new versions, hooked in same place as the old ones. Replace the cords with the black upgraded versions and reverse the above procedure. You shouldn't have to remove the washer from the counter to do this. Just take your time and don't get frustrated--I do this all the time, you *don't*. The hardest part is trying to hold the spring forward enough to latch the cord connector onto the hinge. That's where having that coat hanger is a blessing! Otherwise, you're gonna have to pull the dishwasher out of the counter and that can be a real pill. Good luck and I hope I helped you!
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Drain hose cracked and needs
you will have to pull the dishwasher out. and it is best to lay it on its back in order to get to it. there is also a clip in the bottom that holds it in place, all you need to do is pry it up and thats it all set.
Our stainless LG dishwasher does
First
perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar
into the bottom of the dishwasher. Keep the temperature at the highest
setting possible and perform a wash cycle.Then start using a dishwasher
most probably that would solve the problem. If this does not solve the
problem then there must be some parts worn out or faulty creating the
problem.
There are many probable causes of failure .
To
clean the dishes the water temperature is essential.It the water is not
hot then the dishes will not be cleaned properly.So check the water
temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
LG model LDS5811WW/02 has never cleaned the dishes
if the soap/detergent isn't completely rinsing out of dispenser, it sounds like water isn't directed the top spray-arm. possible a defective vario motor; as it directs water to the water channel that supplies water to the middle and upper spray arms.
