20 Most Recent
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Questions & Answers
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Light is on for heat dry but won't allow me to
Hi
Open the door.
Within 3 seconds press the following sequence --Try pressing normal wash,
heated dry, normal wash, heated dry, normal wash, heated dry three times within
6 seconds and then press cancel to reset the dishwasher. If that doesn't help
then try pressing Saini
Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air
Dry, Saini
Rinse, Air Dry, Saini
Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door
and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally.
If the light is still blinking try and reset the power to the dishwasher and
try again. If still the light is blinking then check for the connections on the
keypad, it may be due to moisture or shorted connections on keypad.
Hope this
helps... Please post back if you need more information.
Daniel
Underlight does not turn off
Thank you for your post, Michael Fiedler!
I understand that the light under your Frigidaire dishwasher is not turning off. It could be a miscommunication within the board or connector. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for roughly ten minutes. If that does not help to resolve your issue I would recommend having a professional technician come out for a proper diagnosis and repair. The technician will have the appropriate tools needed to help pinpoint the fault within the dishwasher. Hope this information is helpful. -Matt
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Frigidaire professional dishwasher buttons don't work
I appreciate your inquiry, friend!
I have identified a few possibilities as to why the buttons are not working on your Frigidaire Professional dishwasher. It could be a stuck button on your keypad and I would recommend pressing every button to see if one is stuck or loose. It could be that the keypad or control panel needs to be replaced. This is not a simple DIY job and I would recommend reaching out to a professional technician for proper diagnosis. I hope this helps. -Matt
Frigidaire error code .10
Hi friend, thanks for your post!
I understand that your digital display on your dishwasher is reading ".10". However ".10" is an invalid error code and could stand for ten minutes left in the cycle. I would recommend a reset to your appliance which can be done by unplugging or flipping the household circuit breaker off for roughly ten minutes. I hope this helps to some degree. -Matt
I have a Frigidaire model#PLD4555RFCO
Hi
"Er Clean S" is a common error with Frigidaire which means
shorted keypad. The issue is with the touchpad/keypad that should be replaced.
However, before replacing the keypad you can unplug it and take it apart
completely and use a hair dryer to blow some warm air on the keypad assembly to
blow the moisture off. Hope this helps...please post back for further
assistance.
Daniel
Can't start dishwasher unless I have it on a delayed cycle
Good Afternoon Leslie,
I understand you are unable to start your Frigidaire dishwasher unless it is on a delayed cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Vent assembly smoking
Its not the vent that has failed. You need to find out why the dishwasher is making smoke. The vent is only where it comes out. If you know what you are doing repair the dishwasher, if not replace it.
Doesnt seem like water is heating and element not getting hot
Sounds like you checked the basics. Do you have hard water? Our element got covered with calcium over time and didn't heat efficiently anymore. I was able to chip some off, then ran the dishwasher with LemiShine a few times. The element worked much better after that.
