20 Most Recent
Pentax Optio Z10 Digital Camera Questions & Answers
Is there a way to retreive deleted photos
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This blog article reviews and outlines several of the better ones.
I found this camra in the cuboard it was my dads
Is the battery fully charged? If the battery pack was in the camera the entire time then it's probably no good now and needs to be replaced. You also want to check inside the battery compartment for any signs of corrosion.
The battery is charged, but
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
My camera is all messed
capacitors are embedded in the circuits of these cameras which hold needed additional power to operate. When a capacitor gets weak the camera will offer these odd operations such as yours here. Repair cost usually outweighs the cost of a replacement camera these days
The sd card in my optio z10 says it's locked. How
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Put in new batteries no response wont
HI there try to clean the battery compartment and and then try. After that if not work then i am sure the camera power suply transformer is damaged anmd thats why itws not able to receive power from the battery. So you need to repair your camera from the camera service center. Thanks.
How to format memory card pentax optimo z10
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
How can I obtain a replacement lcd view screen?
If you are very sure that you want to try to replace it yourself, try eBay. Tell me your location if you need help finding out possible stores nearby. It would be better if you take it to the service center, as a camera being a calibrated instrument.
