20 Most Recent
Polaroid i531 Digital Camera Questions & Answers
Polaroid i531 Card Error
Recuva and RePicvid are also free to recover photos. The best solution is to create a backup for the important photos to avoid loss again. https://www.gihosoft.com/free-photo-recovery.html
I want to get full view picture of a tall desk but
I will assume that you have already tried rotating the camera ninety degrees so that you take the shot in portrait format. Unless you can move the item outside to enable you to stand further back then your only option is to buy and fit a supplementary wide-angle lens to your camera or to use a different camera with a wider-angle lens than your camera has.
One other option is to take two photos and to then use special software to stitch them together (not ideal) or to take the best full length photo you can and then post supplementary photos showing the upper and lower halves of the desk.
How do i get my camera from having a time delay between flash and actual picture
This is a common situation with compact point&shoot cameras. Between the time you press the shutter release button and it takes a picture, it has a lot to do. It has to find the subject and focus on it, meter the light and set the exposure, perhaps set the white balance, and other things. Larger, more powerful (and more expensive) DSLRs have more powerful processors and additional hardware to speed up the process.One way you can reduce this shutter lag is to press the shutter release button halfway to focus and meter before you need the picture. Keep the shutter button pressed halfway until the action hits its peak, then press it the rest of the way.
How do i unlock the card
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Digital Cameras i lost my cd. how do i down load
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as iPhoto on Mac or Windows Photo Gallery on Windows.
Do not know what botton
Manual
HEREhttp://camera.manualsonline.com/manuals/mfg/polaroid/i531.html
I think it's the 3rd button down under the left side of the zoom button.
The zoom button is the long one on the top right corner on the back of the camera.
TickMagnet
Okay i have the polaroid
Try NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Hi, on connecting to USB
Maybe it's because its not supported, well what you can do is to plug the memory card into a card reader and just get the files from there.
Some photos are not opening in the computer., how
It's probably because you don't have the necessary software to open them, Some software is provided with the cam on a CD. Install them if you haven't already done so. If this still doesn't fix it, you're going to have to obtain the software from somewhere, You can use GIMP which is free and opens just about any picture:
http://www.gimp.org/downloads/
Good luck :)
How to change date and time for Polaroid i531
Press the menu button, scroll sideways (press lightening icon) to Setup (tools icon), then down (disp) to highlight date and time. Press Set or the lightening icon to select the date and time setting, then press disp or the opposite upper part of the rocker to change the numbers, and the lightening or flower to move between the various date and time settings. Press Set when you are through.
If you leave the battery out of the camera for 48 hours, you will be invited to set the date and time at the next switch on.
You can download a manual for a similar camera, the i1036, at polaroid.com, but there does not seem to be a manual for this specific camera there. Try
THIS LINK
My daughter dropped her camera and now when u turn
The shock has jarred something loose from the inside lens assembly and the camera is shutting down to prevent further damage. It will need to be repaired (probably not economically worth it) or replaced.
How do you turn o and off flash
Your camera has 4 modes flash function :
1; Flash Off ( flash will Off in any shoot)
2. Flash Fill in ( flash always On)
3. Auto Flash (Camera decided flash)
4. Red Eye reduction flash ( Camera decide flash).
You can set your flash base on your need.
Need program for the computor
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
