20 Most Recent
Samsung Digimax L730 Digital Camera Questions & Answers
I've recorded videos on the camera and when i want
There is a chance that you don't have the correct or updated audio and video codecs installed.
Codecs are required for playing the latest video and audio files.
Go here and download and install XP Codec Pack. Restart your computer and try playing one of your video's.
Get XP Codec Pack here >>>>>
http://www.xpcodecpack.com/download
If you need anymore help please post back.
Samsung L730
My son has a Samsung digital camera and bought a Samsung SAC-45 USB Digital Camera Charger and a Samsung USB Data & Charger Cable Type4 SUC-C2.
He is able to charge his camera by plugging the cable into a USB outlet on his computer, but cannot get the camera to charge when using the SAC-45, which plugs into a wall 110 volt AC socket on one end and the cable on the other.
So far we have tried three SAC-45 units, keeping the same cable, and Samsung says they are shipping a fourth SAC-45 unit.
I think there is some problem with the cable, but haven't been able to get Samsung to send another cable.
We cannot see the photos
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Lost disk for installation of my samsung L730
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Samsung L730
You don't need to install anything.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Transfer data
It plugs into the bottom of the camera. See the illustration on page 10 of
this manual.You might want to consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Samsung L730 - How to download pictures to PC
Picasa.
Is my camera compatable with windows vista
It doesn't matter to the camera what operating system you have on your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
How do i show a video from the camera on the computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer then you can play/view them on your computer.. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
