20 Most Recent
Samsung Digimax L830 Digital Camera Questions & Answers
I need a manual for Samsung L830
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=1854291&CDCttType=UM&ModelType=N&ModelName=SAMSUNG L830&VPath=UM/200802/20080221092928218_L830_L730_English.pdf
Hello, I have a samsung es55 camera and need to
I'm working on the premise that you've deleted the photos from your camera memory or memory card.
If you have and used them since, its unlikely that you'll be able to retrieve them, you could have already over written them.
Its unlikely that you've deleted to your recycle bin, thats on your PC, usually already on your desktop. Camera's normally delete for good.
However, check your pc recycle bin, just double click onto it, it should be on your desk top. Once open you can choose to restore deleted files.
There are 2 file recovery programmes available for free from "filehippo.com" called "recuva" and "PC Inspector File Recovery 4.0". Download and install either of these onto your pc and recover from you camera memory to your pc (just create a folder on you desktop".
Good luck.
Why does the video recordings now in black & white when previously was in colour
I had a similar problem with different camera and contacted the manufacturer. The tech told me this can happen when the batteries are low and the camera converts to B&W to save energy.
Or, the tech said, you may be shooting in light so low that the camera is converting to night vision which is always B&W. If your camera does not have a night vision feature, you might want to check the batteries. They also told me not to use cheap AA batteries.
My computer no longer recognizes my Samsung L830 camera
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
NEED TO PURCHASE SOFT WARE
You don't need to purchase any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free
Picasa.
