20 Most Recent Trendware TEW-432BRP 54Mbps Wireless Firewall Router Questions & Answers
I have a trendnet wireless
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard. I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet. http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/ https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html Note the default gateway is going to have to be the windows 7 ip address on the other computers You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
3/18/2017 12:41:15 AM • Trendware... • Answered on Mar 18, 2017
Problem with firewall rules and access from WAN
  • call your router support to disable first the firewall on the WAN setup
  • the do port forwarding
8/12/2009 2:11:35 AM • Trendware... • Answered on Aug 12, 2009
Trendnet router tew-432brp
the best thing to do is go to there website and call their tech support.. theyre actually pretty good!!.. cause i have the same brand of router but different model.. i called them and they'll walk you through it..
5/7/2009 6:28:27 AM • Trendware... • Answered on May 07, 2009
I can not open the webside completely
Try restoring the web browser settings on your wireless computer.
3/8/2009 9:41:55 PM • Trendware... • Answered on Mar 08, 2009
Wireless is not secure
Step 1 Log into the RouterA device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
Examples:
Authentication type:WEP WEP
Type: Open
System Mode: Hex WEP
Key: 64-bit Key 1: 0000000000
Note: For WEP you can choose ASCII or HEX modes.
64bit ASCII = 5 digit ASCII key.
64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
128bit ASCII = 13 digit ASCII key.
128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
You can also choose WPAWi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA-PSK. The key must be between 8~64 digits.
Authentication type: WPAWi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA-PSK
Passphrase: omg laserbeams pew pew pew
Confirm passphrase: omg laserbeams pew pew pew
1/6/2009 12:02:26 AM • Trendware... • Answered on Jan 06, 2009
Cannot access the network
you have to call you phone company, they can run a test on it, they can reset the code in it. all the lights have to be on for it to work.
11/28/2007 4:52:40 AM • Trendware... • Answered on Nov 28, 2007
0answers
Hello , I have a
Be the first to answer 3/8/2017 11:09:04 AM • Trendware... • Posted on Mar 08, 2017Be the first to answer
0answers
0answers
PC doesn't see mouse, but sees 2 keyboards
Are these PS/2 devices or USB, Mix?
1/30/2013 2:10:50 AM • Trendware... • Answered on Jan 30, 2013
Instal the passward
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
8/26/2012 7:06:23 AM • Trendware... • Answered on Aug 26, 2012
I have been trying to
You didn't state what kind of router that you are using with this wireless adapter. Your adapter is 150mbps so we know it is N technology.
It sounds like it is a security issue. I would suggest making sure that your security is matched perfectly being WEP, WPA, etc etc. If you are manually typing you broadcast ID into the setup for the adapter, it could be the spelling or punctuation. I have seen many people (including myself) have issues from leaving out 1 capital letter.
Having traded out the adapter for a new one you have eliminated that from consideration.
6/17/2011 4:37:22 AM • Trendware... • Answered on Jun 17, 2011
Trendnet 633-GR won't connect to the internet
Well I think that the internet is down from your ISP side
Did you try to call the internet service provider ? Your ISP must be DSL .
with the message " ue Mar 09 13:06:51 2004 PPP network down [INFO] Tue Mar 09 13:06:51 2004 WAN interface is down [INFO] "
It seems that the internet is down on the modem.
Click Here for more info about networking
4/3/2011 12:40:07 PM • Trendware... • Answered on Apr 03, 2011
Where do i plug in the internet cord
Go to the manufacturer's website, find your product and read the instructions.
http://www.trendnet.com/?todo=home
11/28/2009 7:45:38 PM • Trendware... • Answered on Nov 28, 2009
Computer says no network connction
Hello greydolf,
The trendnet router emulator web page may provide some assistance for configuring the network connections. But first, it's best to make sure the basic setup is is correct. Please review you current configuration and make sure everything is hooked up according to the instruction booklet. Then reboot the pc. This is the trendnet help/status web link: http://www.trendnet.com/emulators/TEW-611BRP/TRENDware%20MIMO%20Wireless%20Router%20%20Help%20-%20Status.htm . I hope this web site can help you with the router connection issue.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
7/31/2009 4:55:38 AM • Trendware... • Answered on Jul 31, 2009
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered Yesterday
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered 2 days ago
Trendware TEW-432BRP 54Mbps Wireless Firewall Router Logo
7 questions posted
Top Trendware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Trendware Computers & Internet
Most Popular Question
trendnet wireless
  • Computers & Internet
