20 Most Recent
Sony Ericsson P1i Questions & Answers
Security code
Enter this in your phone 3543561762 and your phone will be unlocked
thanks.
SMS sending failed
Please try this to find a solution to your problem. Go to Messaging window and select More. Select Settings and SMS account subsequently. Make sure that the 'Connection Type' is 'GSM preferred'. And in the 'SMS Service Center Address' check with your operator Customer Care and make sure the same number is entered. You could tell the Customer Care of your problem and that you wish to verify if your using the correct service center address.
Hope this helps
My Sony Ericsson P1i doesn't start
Hold on the rest for 10 seconds.This will restore the settings to factory defaults but you will loose all your data and this the only solution.
Goodluckk..
P1i not charging when connected to computer
USB ports supply very low voltage and may possibly go bad on the PC itself. Does the unit charge on a typical wall outlet plug? If not, then the DC jack on the phone itself is bad. Repairing this may be more costly that just buying a new phone.
P1i wont boot
got the same problem today, was strugging to make calls, the decided to reboot.. its not going past 3/4 of boot sequence.. still investigating..
