20 Most Recent
Canon MP520 All-In-One InkJet Photo Printer Questions & Answers
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (
canon), click "OSX" on the dropdown list for what os you're using, then click "
mp520sosxsd1391ej7.dmg" under "
MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
I am unable to print
- Remove copying and printing restrictions from PDF files; Remove Open Password from encrypted PDF files with authorized password
How do you load 4 x 6 photo paper
If you look at the back of the printer were you load A4 size paper you should be able to see guides that keep the A4 paper steady you should be able to adjust these slides to the size you want.It explains it in the manual: http://www.manualowl.com/m/Canon/PIXMA-MP520/Manual/122481
5B10 error on Canon MP520 printer
Hi there
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link =
http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
: Pineworks
All files on my website are only there for a limited time
