20 Most Recent
Canon MX310 Office All-In-One Printer Questions & Answers
Problem with Code 6000
Hello, according to another expert at fixya:
"Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board. "
Does the MX310 have OCR?
Yes according to Canon's support site found on the link below the MX310 does have OCR using the Scansoft OmniPage SE software bundled with the printer.
http://www.canon.co.uk/for_home/product_finder/multifunctionals/inkjet/pixma_mx310/index.asp?specs=1
I am still unable to
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit
www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How to fix a 5100 fault
Remove the cartridges. Inspect the cartridges to ensure all packaging is removed. Reinstall the cartridges. Press the ON/OFF button for 2 seconds. Unplug the printer and wait 10 seconds. Check the printer for any obstructions including packaging materialsRemove the scanner cover. Open the lid - check for paper that is stuck; these can be very small pieces, so look carefully
Plug the printer back in and power it on.If that does not solve the problem you will have to contact repair
I AM TRYING TO INSTALL MY CANON PRINTER TO MY PC
You may want to download the drivers software from producers website www.canon.com
You should go to support page and download the software.
Once you have download the software you should install it on your system.
Let me know if you solved your problem
