20 Most Recent Canon PIXMA MP210 Photo All-In-One Printer Questions & Answers
Canon MP210 takes paper crooked and spits out crooked or jams. How to fix? Followed manual for cleaning feed roller but to no avail. Thanks
could it be a paper clip fell into the paper feed slot? see if you can shine some light into the slot and use a dentist's angled mirror to examine. sound like debris may be the culprit. disassemble it to the extent that you have ability to. LEARN THAT WAY!
12/1/2021 12:45:25 PM • Canon PIXMA... • Answered on Dec 01, 2021
E6 en kan niet printen
this is an ENGLISH ONLY website
10/30/2021 4:02:36 PM • Canon PIXMA... • Answered on Oct 30, 2021
MP210 canon printer showing E6 error
it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release it.
10/6/2021 3:29:45 PM • Canon PIXMA... • Answered on Oct 06, 2021
Error 5100 on canon MP210.
NEW but were they OEM
10/1/2021 4:49:48 PM • Canon PIXMA... • Answered on Oct 01, 2021
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
1/14/2021 12:48:34 PM • Canon PIXMA... • Answered on Jan 14, 2021
Printer setup
mujhe canon pixma mp160 ka software chahiye
12/28/2020 12:08:49 PM • Canon PIXMA... • Answered on Dec 28, 2020
3answers
Error code 6000 on canon pixma mp210 stops me from printing
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this failure. There are several explanations why Canon Printer Error 6000 will happen when you work with a Canon printer. One of the factors is that one of the most simple common explanations is where the paper feed tray is blocked by certain dust particles and bits of paper. Another reason for this is that the paper feed tray is not adequately connected to the printer. If there is a tonne of a print order. Reasons that cause Canon Printer Error Code 6000: 1. The feed tray of the printer is improperly fitted. 2. A large number of documents near the printer. 3. The line feed is scratched or smeared. 4. Giving multiple paper print commands at once. 5. Faults within the sensor unit or in-line feed slit. Follow Blog: Canon printer error code 6000 Thanks for reading.
12/26/2020 7:40:12 AM • Canon PIXMA... • Answered on Dec 26, 2020
2answers
Printer not responding
Test your printer on an ordinary document. If it prints OK it's not your printer or document.
10/11/2019 5:24:05 AM • Canon PIXMA... • Answered on Oct 11, 2019
2answers
/*mp250 error code p03 alarm
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
8/10/2019 7:58:13 AM • Canon PIXMA... • Answered on Aug 10, 2019
2answers
My printer has no power i have changed the fuse on the plug but still no power. Does the printer has a fise and where please
It should have a fuse on the internal power board so look at where your power cable enters then you should see glass fuses, check them and you can normally see if the thin wire inside has split or if the fuse has turned black.
5/12/2019 11:34:13 AM • Canon PIXMA... • Answered on May 12, 2019
3answers
Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
(11/24)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
11/12/2018 1:59:02 PM • Canon PIXMA... • Answered on Nov 12, 2018
2answers
Is MP210 and MP240 the same? can i use the same
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
8/14/2018 5:09:35 AM • Canon PIXMA... • Answered on Aug 14, 2018
Blank pages
download the driver that is compatible with mac for your make of printer
3/2/2018 2:51:36 AM • Canon PIXMA... • Answered on Mar 02, 2018
My Canon Pixma MP210 prints only red and blue
Canon makes it ******* owners by using a small electronic chip on each cartridge that opens when it is taken out of the printer. Sometimes removing a cartridge will not open and when replaced in the print head, it works, but if the cartridge sensor fails to communicate with the printer, you would need a resetting device to bring the cartridge back to normal. Rather than become upset with the issue, it would be best to get a new cartridge from any reseller on the internet (not Canon) and go from there.
2/20/2018 5:40:24 PM • Canon PIXMA... • Answered on Feb 20, 2018
How do I scan document to a file on computer? The
suspect you do not have the cannon scanning software installed. suggest downloading the drivers from cannon https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp-series/pixma-mp210?tab=drivers_downloads Then hopefully the program for scanning is installed. and it works out how your scanner is connected to your pc ?
1/15/2018 11:08:32 PM • Canon PIXMA... • Answered on Jan 15, 2018
0answers
Paper not feeding into Canon Pixma MP210 printer.
https://www.youtube.com/watch?v=2qM5By8V8IM
6/20/2017 5:33:30 PM • Canon PIXMA... • Answered on Jun 20, 2017
2answers
My canon MP210 has an E5 error. How do I reset
Hello there:
here is the normal step for this procedure.
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • I hope that you find this very helpful for you
  • Please dont forget to rate this for me it helps me so i can continue helping others
  • Best regards michael
4/1/2017 5:07:44 PM • Canon PIXMA... • Answered on Apr 01, 2017
PIXMA MP210 set up CD ROM doesnt work.. how do i download?
Hi - Below is a link for your drivers and software. Just choose your operating system. Sometimes the site is slow. If there is more than one version of any software get the latest version. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402
Jeff
11/10/2016 5:37:02 PM • Canon PIXMA... • Answered on Nov 10, 2016
Canon PIXMA MP210 Photo All-In-One Printer Logo
1,520 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
driver
  • Office Equipment & Supplies
