20 Most Recent
HP Deskjet 2460 InkJet Printer Questions & Answers
Flashing led power button on deskjet d2460
try to check your cartridges. Pull it out one at a time then try to see it it stop blinking. Especially cartridges that was refilled. Improper refilling of cartridges causes them to stop responding to your printer and causes to malfunction. this was base from my experience.
Hp d2460 slow printing
the next time you print something, click printer properties and choose default settings. Photo fix may be on..
My hp deskjet ink adv2060 K110 not print the
Hello there Marejen,See if there is any spooler.exe running in your task manager. Press ctrl, alt + delete to go there. If you see the process, click to highlight then end it. Then restart your computer and the printer itself. Then try to initiate a print again once everything is loaded.Please let me know if this helps. Thank you for using FixYa.
Hp continuous blinking
According to your problem first check the cartridge of the
printer. Either refill the cartridges or better to replace it. Because the
problem may occur for blank or bad cartridge only. So clean the head and
replace the cartridges.
Hi..i have a problem with
go to the internet and type in the address bar www.hp.com (this is the official website for hp products)
once your in that page, locate for the support and drivers box and type
HP Deskjet D2460 Printer then click the small icon search , this will lead you to another page SEARCH RESULT page
choose the software and driver download , then follow the rest of the instructions
Power button light flashing continuously
Hi
Yes you are correct the cartridge(s) need to be replaced.
Usually the color cartridge need to be replaced. But just in case try to do the following
1. Turn on the printer
2. Open the top cover
3. remove the cartridges from printer
4. Clean the contacts inside the printer and on the cartridges
5. install them back and try.
OR
Let the printer finish the normal initialization process, then hold the power button and open and close the top cover 3 times. The printer will print the diagnostics page and in this the cartridges status is printed hence you will come to know which cartridge needs to be replaced.
DO RATE MY SOLUTION
Printer D2460 blinks not print
The HP printer may print incomplete characters. This issue occurs due to clogging of print heads. So this problem can be solved by cleaning or replacing the print heads. Sometimes the printer will not accept the paper tray. At that time, you have to turn off your printer and disconnect the printer from its power source and reconnect the power and then turn the printer on. The printed pages will sometimes come out skewed, this may be due to curled or torn paper become jammed inside the printer. One easy remedy for this problem is that, you have to remove the torn pages from the paper tray and smooth down all the curled edges of the paper. If the settings of the printer are not correct or the paper tray is overloaded, the printer may pick multiple pages for printing, which could result in paper jam.
Get more help to fix
HP Printer Not Printing error. Hope this helps you.
All time: I have stalled
first remove the power plug and the usb from the printer wait for few minutes and place them back first the power then the usb then press start setting printer and go to printer propertes in printer page you will see the printer drivers which are instaled make the prinriter you are using as defult if you see no printer drivers then install the software which came with the printerall the printer software should be installed then go to the taskbar you will see the printer icon click them to open then delete all the contents then click to close then go back to the printer page right click the defult printer and click tgeneral in general you will see print atest page click it
Erm i hv a prob
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA.
My hp D2460 inkjet printer
Time to change the ink cartridges
Or check for any paper jam
and wether the carriage is moving perfectly
if everything above is OK
its time to get a new printer....
