20 Most Recent
OKI C9600hdn Laser Printer Questions & Answers
OKI C9600hdn fatal error 133
My OKI C9600 printer has problem related to led head with error code 133. This error msg indicates Cyan led head is failed.
There are some reasons that leading to this failure. One of them might be caused by drum. If drum is dirty or is overflown by toner.
So you may test C Led head to know it is OK or not. How to test ? Try changing with another Led Head such as Y,K, M.
This is the way I did, and my printer is OK now.
Oki not printing pink
Seen this many times. Its because you are using recycled drums and/or toner. With the genuine items you will find the magenta will be more red than pink.
I have an okidata printer c9600, and it is printing a grayish background where in white areas.
The white area gets dirty. (Figure 7-2 )
• Has the image drum been exposed to external light for a long time?
YES Replace I/D Unit.
• NO Is the fuser unit roller dirty?
YES Replace the fuser unit.
• NO Correct the [Paper Thickness] setting.
NO Properly set the [Paper Thickness].
• YES Replace the LED head.
Has the problem been corrected?
YES END
• NO Replace the engine PCB (S2V PWB).
YES END
• NO Replace the head shield cable.
YES END
• NO Check the cable connection, then replace the low voltage power unit.
YES END
• NO Is +24V output to the HVOLT connector Pin 16 of the Engine PCB (S2V PWB)?
NO Replace the engine PCB.
• YES Check the cable connection, then replace the high voltage power unit or belt unit.
Has operation been restored?
YES END
• NO Is the I/D unit terminal properly connected to the contact Assy?
(Refer to Figure 7-3)
NO Properly connect the I/D unit terminal to the contact Assy.
• YES Replace Image Drum Unit.
Note! 1. When replacing the Engine PCB (S2V PWB), remove the EEPROM from the old
PCB, then mount that EEPROM on the new PCB.
2. If the EEPROM is not going to be replaced, refer to Section 5.2.2.
What causes a dirty background?
Copied
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
I have replaced waste toner unit with new one on a
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer. NOTE: This should solve most problems with printers.If still not working you have a faulty Toner unit.
