20 Most Recent
Samsung SCX-4725FN All-In-One Laser Printer Questions & Answers
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
11/6/2021 5:52:16 PM •
Samsung...
Answered
on Nov 06, 2021
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
3/9/2015 3:23:01 PM •
Samsung...
Answered
on Mar 09, 2015
Printer humming noise
Dear
If refilled toner cart used without proper cleaning, the rollers may sticked and jam so motor try to move but could not, make it free or remove the toner cart and hear the moving sound. or you may try with another cart. Else motor or main PBA fails.
Thanks.
3/4/2015 12:11:43 PM •
Samsung...
Answered
on Mar 04, 2015
Printer gives error message "install toner"
Hi Steve,
The waste toner tank is the gray L-shaped container to the left of the cyan (blue) toner cartridge. Pull on the tab handle and either shake out the waste toner into a deep trash can (VERY messy) or outside into a trash can, then replace the old one if emptied or use a new one. Should be able to get it at a larger office supply store. Hope this helps.
4/25/2014 1:49:36 PM •
Samsung...
Answered
on Apr 25, 2014
How do you scan with Samsung SCX-4725fn?
Having encountered this issue, I read the manual. The only way I found it to work was to press scan and then choose the application that you want to use. I normally just choose scan to Paint. Then launch Paint on your pc, Go to File and select From Scanner and Camera and your image will appear in Paint. (not the easiest scan method in the world but it works; I have tried selecting the other applications on the scanner menu but haven't had any success.
6/6/2013 8:19:00 PM •
Samsung...
Answered
on Jun 06, 2013
Eoj problem
I know this is an old post, but I still feel it will help to post my solution in case anyone else has this problem. I deleted the Samsung 4725fn PCL6 driver from each computer and added a Universal Print Driver from the Samsung website locally to each PC that connected to this printer via the network. So far, the Universal Driver has solved the End Of Job (EOJ) page from printing after each print job. Hopefully this will help someone else.
7/8/2012 1:34:05 PM •
Samsung...
Answered
on Jul 08, 2012
