20 Most Recent Kodak 5500 ALL-IN-ONE PRINTER Questions & Answers
0answers
Office hero 6.1 will not turn off or respond.
I had same problem - just contacted Kodak live chat, they talked me through a couple of fixes which didn't work, so they ordered me a free replacement. The printer was 9 months old.
8/29/2012 8:59:02 PM • Kodak 5500... • Answered on Aug 29, 2012
PRINTING DISSORTED LIGHT AND DARK
pls check the printer test pages if no faint in printing if faint occured it need cleaning
11/6/2011 5:08:13 PM • Kodak 5500... • Answered on Nov 06, 2011
The switch on my printer will not turn my printer
have check it to the service center for a better check up
11/6/2011 5:04:55 PM • Kodak 5500... • Answered on Nov 06, 2011
Explain how to use the scanner
be sure that the printer is connected to the computer then if you already install the driver of it try locate the software for the scanner then you can scan anything
11/6/2011 5:00:47 PM • Kodak 5500... • Answered on Nov 06, 2011
2answers
There is a system error at runtime Cide: 101-8193
if it is tonner replace it, if it is ink cartridges replace it, think it may help god bless
11/6/2011 4:45:47 PM • Kodak 5500... • Answered on Nov 06, 2011
HI no image or text is being printed..just blank
Your out of ink in your toners just refill or get new ones
7/22/2011 11:31:19 PM • Kodak 5500... • Answered on Jul 22, 2011
0answers
2answers
Won't print black after changing cartride
Call 1800 421 6699
Printhead needs to be replaced.
It free of charge replacment
3/18/2011 1:19:26 PM • Kodak 5500... • Answered on Mar 18, 2011
How do i transfer info to my computer does not
You will need to go Here and download the drivers to whatever pc you are trying to print from.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
3/6/2011 8:13:38 PM • Kodak 5500... • Answered on Mar 06, 2011
3answers
I am trying to connect
To resolve the error, make sure your printer is connected to your computer either with a USB cable or through a wireless network.
If your all-in-one printer is connected through a wireless network:
  1. Open System Preferences.
  2. Open the Print & Fax from the Hardware section.
  3. Click the +.
  4. Highlight your all-in-one printer in the Bonjour list and click the Add button.
If your all-in-one printer is connected with a USB cable, the printer should be added automatically. If the error continues after connecting the USB cable, make sure:
  • USB cable is connected securely to the printer and computer
  • Printer is connected directly to your computer, and not through a USB hub or other device
  • You are using a USB High Speed 2.0 cable and the distance between printer and computer is less than 1.8 m (6 ft).
If the error continues:
  1. Disconnect the USB cable from the printer and computer.
  2. Connect the USB cable to the back of the printer; make sure it is securely connected.
  3. On your computer, open System Preferences, then select Print & Fax from the Hardware section.
  4. Connect the other end of the USB cable to your computer.
  5. Monitor the Print and Fax window; when the computer detects the printer it will appear in the printer list.
  6. If the printer does not appear:
    • Connect the USB cable to a different USB port on your computer.
    • If the error continues, use a different high-speed USB 2.0 cable.
NOTE: You can test your USB cable by connecting another USB device to your computer using the USB cable.
2/15/2011 11:09:51 PM • Kodak 5500... • Answered on Feb 15, 2011
My ink levels show that i still have enough ink
The head nozzle on the cartridge is clogged - clean the cartridge print head with "Q" tip and alcohol.
12/11/2010 11:33:02 PM • Kodak 5500... • Answered on Dec 11, 2010
My Kodak ESP 5250 won't
First thing to do is download this free registry cleaner and then scan your computers hard drive.
http://abexo-free-registry-cleaner.en.softonic.com/
After you do that, redownload the software that controls your Kodak ESP 5250. Now, restart your computer for the changes to take effect.
http://support.en.kodak.com/app/answers/detail/a_id/17138
11/20/2010 3:06:57 PM • Kodak 5500... • Answered on Nov 20, 2010
Lost instalation disk
www.kodak.com/
Try to locate your driver from the manufacturer.
11/19/2010 3:33:36 PM • Kodak 5500... • Answered on Nov 19, 2010
KODAK ESP 7 AIO Carriage stuck
optical encoder is known as the timing Strip film that guide the carriage of the cartridge, you have to clean softly with a cotton and alcohol.
10/30/2010 12:42:08 PM • Kodak 5500... • Answered on Oct 30, 2010
3answers
Dead print head
the reason why the printhead is going bad is because this was a problem with the printer since it was launched since day one all tech support will do is replace the print head but if u call them and ask them to escalate the case to a manager and you need to act very irate then maybe and just maybe you should get a refund.
the printhead keep rubbing against the bottom of the carriage in this printer causing the contacts to wear off really fast and thats the problem ur facing ,it was one factory faulted printer that was launched
10/20/2010 9:35:32 PM • Kodak 5500... • Answered on Oct 20, 2010
2answers
Kodak 5500 All In One Printer set up problem
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
9/28/2010 4:48:36 AM • Kodak 5500... • Answered on Sep 28, 2010
Kodak 5500 ALL-IN-ONE PRINTER Logo
Popular Tags
65 questions posted
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kodak Office Equipment & Supplies
Most Popular Question
system error runtime cide 101 8193
  • Office Equipment & Supplies
