20 Most Recent
Casio Parts Cash Register PC Desktop Questions & Answers
How do i reset my grand sales on a casio TE 2000
very simple solution with no reprogramming of the unit.
- in Z mode: make a report and read the grand total sales amount
- in RF mode make a refund of that amount
- in Z mode make a report again to check that the grand sales is zero.
IBM Toshiba SurePOS 4852-580 15 , cash register.
If an IBM Toshiba SurePOS 4852-580 15 cash register that you purchased used is not allowing you to make any changes and says "unauthorized," there could be a few possible causes:
- The cash register may be locked by a previous owner: The cash register may have been locked by the previous owner with a supervisor password. You will need to obtain the password to make changes.
- The software may be outdated: The software may be out of date and require an update. You will need to contact IBM for assistance with this.
- The system may have been tampered with: The cash register may have been tampered with, which could have caused the system to become locked and require a service technician to reset it.
- The cash register may have a security feature enabled: Some IBM Toshiba SurePOS have a security feature that allows only authorized users to make changes. You will need to contact IBM for assistance with this.
- The cash register may have an issue on the hardware: some issue on the hardware of the device could be preventing the device from functioning properly.
Casio ce6000 error code e004
That means it is having trouble with the memory backup. Don't unplug the machine as it is about to lose all programming and sales data. Has this machine been turned off for a long period of time? When was the battery last replaced?
My Sharp Cash Register (ER-A410) won't turn on in manager mode
Hi.
It is usually caused by a faulty or dirty mode switch. The first thing to try is squirting a bit of electrical lube down the key hole (WD40 or similar works fine), then turn the key back and forth a few times. Otherwise, the contacts inside the switch may have failed. I have also had a loose connector on the main board cause this in another model, so you could try pushing the connectors inside and make sure they are tight.
Hope this helps. You can set the void button to work in REG mode if you don't want to get the MGR mode fixed. Just let me know and I can look up the codes for you. You should be able to refund items as well (unless this has been set work in MGR mode also).
Mark
Need operating manual for Geller NT-1081
You can download a manual here for
4.99 Pounds
http://www.eposwizard.co.uk/catalog/geller-nt1081-programming-operation-manual-p-423.html?osCsid=03b8d93971525f0e1b634a1cdca79f38
I do not have any affiliation with this website. hope the information is usefull to you.
Sharp xe-a20s locked up
Hi.
Yes you are right. you have logged yourself out of the machine. it is telling you to log back in.
Press 1 then CLK# or CASH#
Mark
Just purchased a casio PCR T2100 cash register,
1. Turn key to program
2. press 2 subtotal
3. press 132 subtotal
4. enter commercial message using alphabet keys on keyboard (21 character max per line, 4 lines)
5. press cash at end of each line.
6. press subtotal when done
7. turn key back to reg
Error code Eo2
HI.
Error 2 means no clerk code entered. You need to log on to the machine with your clerk (PIN) number, then press the CLERK or CLK# button. Then it will let you make sales.
If you have trouble, just let me know.
Mark
