Frigidaire Refrigerators • Uploaded on Oct 17, 2013
Hello Chuck Reed - Sounds like the refrigerator has a sealed system issue or the defrost circuit is not completing properly. I strongly suggest contacting a professional to move forward accurately.
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
The manual defrost reset
procedure is as follows: ----
First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced.You
can get the required parts from online sites like:---
www.repairclinic.com or
from searspartsdirect online site.---------This will help.Thanks.Helpmech.
maxico.net
34 questions posted
750 Questions
598 Questions
459 Questions
272 Questions
173 Questions
