20 Most Recent Frigidaire FRS-26DR7D Side by Side Refrigerator Questions & Answers
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Frigidaire... | Answered on Sep 16, 2019
Just a thought. Our frigidaire stainless steel refrigerator came with a temorary protective film on the steel parts that we peeled off after it was installed. Is it possible you never removed your film when you got your refrigerator? That may be what is starting to peel off now. Again, just a thought, I could be wrong.
Frigidaire... | Answered on Mar 24, 2018
If it is the plastic protective coating, it should have been removed after installation. if you scrape with sharp object you will damage stainless finish. good luck!
Frigidaire... | Answered on May 16, 2015
Good Afternoon Friend,
I understand that the ice door is stuck on your Frigidaire refrigerator, model# FRS26BH6CS5. I suggest resetting your refrigerator, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try getting ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 19, 2014
Not to be glib, but one night my wife accidentally LOCKED the dispenser trying to turn on the light (front panel)...there is also a switch to turn off the dispenser inside my Kenmore...I believe in the KISS principle, check the simple stuff first. I assume it is making ice just not dispensing.
Frigidaire... | Answered on Sep 13, 2013
Hello Alfonso, thank you for your inquiry!
I am happy to assist you. By motor, do you mean the compressor is not working? If so, do you hear the compressor running? The compressor is meant to constantly turn on and off frequently to keep unit at a stabilized temperature. If you do not hear the compressor running, the refrigerator could possibly have a coolant leak, an issue with the internal sealed system including a faulty compressor, evaporate fan or main control board.
If you need an experienced technician, you can always refer to the manufacturer website where there is you can easily locate a local service provider in your area. If you need further help, please feel free to reconnect.
Frigidaire... | Answered on Sep 10, 2013
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Frigidaire... | Answered on Jan 13, 2011
Hello, This sounds like you should look at 2 parts. Check your schematic which is usually glued to the motor compartment and look for the Dryer Heater and the Cycle Timer. The Cycle Timer is a device which triggers the Heater in Self-Defrosting Refrigerators. You need to determine if it is working, some have a external twist button which can be used to engage the Defrost Mode. The second part is the heating element which is turned on by the Timer. It is usually within the cavities of the inner shell of the refrigerator box.
Although all Refrigerators are meant to cool and freeze, the Self-Defrost models regularly generate a small amount of heat to lower humidity and to keep the box from icing up as yours has done.
I have had good experience with a business called Servall, which has service parts for all major Appliances. They may be in your phone-book, they are on the Web, and they have an 800 number. You may be able to obtain schematics and info from them and they have been in business since 1929.
Another source of diagrams can be your Library. There are repair books for major appliances there, even by Brand. I hope my solution is very helpful to you. I do not have Servall's number at hand, but it is an affliation of Service companies and one may be a local number for you. If you can find the schematic on your unit, a continuity test will tell you the condition of the 2 parts I mentioned.
For the timer, it must be turned to an active position to register.
Frigidaire... | Answered on Jan 11, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Frigidaire... | Answered on Dec 30, 2010
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Frigidaire... | Answered on Dec 27, 2010
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
80 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
ice crusher stopped crushing
  • Refrigerators
