20 Most Recent
ViewSonic VX2835wm Monitor Questions & Answers
We have a VX2433WM monitor that now has the images
Right click on desktop, choose properties from the pop up menu, in display properties choose the settings tab and set the resolution using the slider to 1920×1080 which is your monitors optimum resolution.
11/13/2014 3:35:02 AM •
ViewSonic...
Answered
on Nov 13, 2014
Viewsonic VX2835wm won't turn on.
There are 2 boards/parts involved with this problema) The power supply board:The main problem are 4 bad/defective capacitors 1. 22uf 400v2. 47uf 50v3. 1uf 100v4. 22uf 35vYou can find them near the PWM IC controller (U601). Replaced all these capacitors regardless they look good. I pulled them out off the board and tested them with my Blue ESR and capacitor tester and found 3 were defective.Next, you need at least 97% Isoprophyl alcohol and toothbrush to clean the soldering paste. Due to overheating on the primary section / HOT section the soldering leads tend to produce brownish paste which is causing the component parts to SHORT. Concentrate at the back of the board, especially at the U102 (16-pin IC) and Q202 transistor by scrubbing them carefully. I used magnifier to make sure the legs are clean and shiny. Clean the rest of the back and some part on top of the board. Let it dry for 2 hours at least. I did 2 times this cleaning to complete the process. b) The Main BoardThe main board has 2 bad capacitors at C124 and C126. I replaced them and cleaned also the board with alcohol.That's it. Good Luck.Roan MacComputer TechChapel Hill, NC
1/25/2014 5:22:13 AM •
ViewSonic...
Answered
on Jan 25, 2014
Vx2835 screen is black
might want to unplug everything and let it sit for a half hour and try to plug everything back in. Try a different outlet maybe.
12/30/2012 7:16:44 PM •
ViewSonic...
Answered
on Dec 30, 2012
I have a viewsonic VX2835wm and when i turn it on
In this model the capactors hardly ever dome or vent. Usually you will see the top of the labeling on the capacitor has shrunk a little from it's normal size. If the monitor still has any kind of power (which it does from your comment) you or someone you know can replace those capacitors on the output side of the supply. If you're lucky this will solve your problem. If not, you can always try replacing the four brown electrolytic capacitors on the inverter board (the long board on the left when viewing the monitor from the back). There is a chance this could be caused by the inverter board or even a bad backlight, however I would bet it's the power board. If you don't want to replace the capacitors or replacing them didn't solve the problem, contact Viewsonic at viewsonic.com and get the price of a new power board. They are pretty easy to replace.
6/3/2012 6:20:08 PM •
ViewSonic...
Answered
on Jun 03, 2012
VX2835M takes a long time to turn on depending on the time turned off
You have a unit with a failing power supply. When the parts called capacitors in the power supply start to fail they can't hold the charge like they should and it take a while for them to build up the charge and allow the power supply to turn on. Once they have a charge built up they work fine until the unit i turned off for a while and their charge drains then it starts over again. Here is a link to a parts kit that you can use to rebuild the power supply board and return the monitor to a working condition.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=178I hope this helps, if so please rate my solution.BuddyMc
3/12/2012 6:30:34 PM •
ViewSonic...
Answered
on Mar 12, 2012
Hi.
Monitor start blinking when
Look for bad caps as you can see in my VIEWSONIC VX series albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
11/12/2011 11:59:44 PM •
ViewSonic...
Answered
on Nov 12, 2011
Vx2835wm
From cold start screen flashes,
Welcome to Fixya. The problem happens to me several days ago. It seems that there is a component on the motherboard that has been burnt. If you're familiar with electronics or electronic parts of the lcd then you can just replace the burnt component like the capacitor, transistor or like. If not better to bring it to a service center to have it fixed. Better not to use it because it can more issue on the monitor because other components can get burnt as well.
Thanks
9/25/2011 12:53:12 AM •
ViewSonic...
Answered
on Sep 25, 2011
When I plug in the power cord nothing happens. I
The power supply on lcd and other flat screen type monitors utilize a group of capacitors as a static pulse for the screen to energize..my bet is that one or more of those have failed...it's actually a common problem with flat screens. Most of them, those that won't power up anyways, have this exact same problem. If it's not that, then your power supply is burnt out, and if that's the case it may be cheaper to get a new monitor instead of trying to fix the old one.
9/1/2011 6:01:25 AM •
ViewSonic...
Answered
on Sep 01, 2011
My power supply is bad
just google search the model number of the power supply.
I would go to ebay and look for it there.
5/19/2011 3:33:14 AM •
ViewSonic...
Answered
on May 19, 2011
Viewsonic vx2835 lcd display Central
The power switch is a TACTILE momentary switch type, it does not latch. You may ahve bad power supply due to bad caps as you can see in my Viewsonic VX series albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
2/28/2011 4:35:17 PM •
ViewSonic...
Answered
on Feb 28, 2011
I would like to know if I can add remote control
Good day,
I think is impossible to to add a remote control if your tv has no IR remote sensor in it. It is only possible to hook up a remote control if you have a PC hook in your tv, by installing PC remote control and TV Tuner that is available in Computer Shops.
2/2/2011 8:17:01 AM •
ViewSonic...
Answered
on Feb 02, 2011
