20 Most Recent
Canon PowerShot A650 IS Digital Camera Questions & Answers
Memory card error message is showing
Just check if all the contacts on the memory card are clean and shiny. And the should not have any bent or dent. You could clean the contacts with a dry cloth or a cotton swap.
If you have a external memory card reader, you could try to read and writhe the card using a computer. If you have all the pictures from the card, save on another media you could try to format the card on a computer (FAT or FAT32) and then again do a format in the camera. See if the filesystem is more reliable then.
CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!!
Glad I'm not the only one... I don't know what to do! I have gotten
brand new rechargeable batteries and instead of getting 250 shots, I
only get like 20!
Canon A650is lens error
Since you have already tried the basic steps just try to apply some pressure and check. If the lens still do not open up you need to get it repaired from a tech shop.
Thanks
No matter what card we
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Card is locked
There is a tiny switch on the memory card that is used to lock to prevent accidental erasure. Make sure that this small lever on the side of the SD card is pushed to unlock.
I don't know how to
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET.
Camera is displaying memory card
That's probably what the error is. My Ixus says "No memory card!" if I turn it on without a card in it, then "Can't Record!" if I try to take a picture. Some cameras have built in memory for pictures and some don't.
All of the sudden I
From now on, use a card reader for downloading your pics. After downloading, format the card in the camera.
