20 Most Recent Archos 605 WiFi Digital Media Player Questions & Answers
2answers
Unable to play DVDs in Windows Media Player & Power DVD
may be if you instal the codec pack wil works
here is the link for download:
http://www.codecguide.com/download_mega.htm
you got to instal in wmp
11/8/2019 3:11:56 AM • Archos 605 WiFi... • Answered on Nov 08, 2019
2answers
No audio on AVI files
Hi :
I would download virtualdub (free), install a divx convertor (free to some level), and input your original file in virtualdub (file-open file), check the video tab from VDUB, click compression, select divx, and save the file as an .avi file on harddisk of yr computer. If finished, check this avi file with a media player (winamp or so), see if it plays correctly, then transfer the file to your Archos. This will work.
I believe, when you converted, a stray codec was used for audio)
Gerard
11/8/2019 2:55:38 AM • Archos 605 WiFi... • Answered on Nov 08, 2019
2answers
Hi there can you plse
look for these programs on google
DVD Shrink 3.2
FLV to AVI MPEG WMV 3GP MP4 iPod Converter
8/17/2019 9:17:47 AM • Archos 605 WiFi... • Answered on Aug 17, 2019
0answers
Archos 5 - Wifi keeps failing
reset the router to factory default ,then set it again ,sometimes routers need this ,you should information in netgear website . Its pretty simple and try setting up wpa ,its more secure
8/6/2017 7:17:53 AM • Archos 605 WiFi... • Answered on Aug 06, 2017
Won't boot up, or show connection to PC, Hard Drive issues
Take it apart and make sure all the connectors are tight.
4/28/2017 7:39:41 PM • Archos 605 WiFi... • Answered on Apr 28, 2017
5answers
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
12/23/2016 7:03:42 AM • Archos 605 WiFi... • Answered on Dec 23, 2016
9answers
Archos 605 battery replacement
I purchased the battery at the link listed here
http://www.newmp3technology.com/605-30-battery.htm
The replacement is not easy, but I was successful
tools reqd':
a very small phillips head screw driver (for cover)
a very small allen key (for hard drive removal)
side cutters
solder iron (very small tip)
small shrink tube (or black elec. tape)
remove the back cover (4 small screws top and bottom of the gray back and 4 small screws at the silver sides of the unit) also be careful here as the screen is now loose and can fall away if not supported
remove hard drive (4 small allen screws) make sure you GENTLY wiggle the hard drive out of plug
the battery is now exposed
this was the nasty part, the battery can be removed out the back but you have to pry it out, I ended up prying and bending the battery to remove it (it was do or die at this point). once you have it loose snip the black and red wires leaving about 3 inches.
the new battery dropped into place very easily.
Strip about 1/4 inch off the blacks twine them together and carefully solder (if you twine them end to end make sure you slip a 1" piece of shrink tube over one before you solder, I twined them side by side so I could slip on the tube after) if you use elec. tape instead of tubing MAKE SURE you leave no wire exposed or you unit will likely be forfeight. Repeat process for the red wire making sure the battery lead does not contact anything but the other red lead.
I laid the 2 solder connections along the top edge of the unit so as not to interfere with the hard drive laying flat
reverse the order to reassemble and that should be that!
My new battery was flat on delivery but has now charged up fully and seems to hold a good charge.
6/14/2015 3:30:16 AM • Archos 605 WiFi... • Answered on Jun 14, 2015
How do i receive freesat tv on archos 101 tablet
Go to this site and download the app: http://www.freesat.co.uk/app THE FREESAT APP
2/6/2015 9:16:26 PM • Archos 605 WiFi... • Answered on Feb 06, 2015
Mylgl35g says wifi error all the time when i try to use wifi?
Did you setup your WiFi router correct. Did you make a user name with password on your Router? did you setup a WiFi login for that account on your smart phone? Just a few questions, you should work out.
6/12/2014 10:57:58 AM • Archos 605 WiFi... • Answered on Jun 12, 2014
Archos 605 WiFi Digital Media Player Logo
437 questions posted
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Archos Audio Players & Recorders
Most Popular Question
archos 605 battery replacement
  • Audio Players & Recorders
