20 Most Recent Frigidaire FEF352 Electric Kitchen Range Questions & Answers
2answers
Replaced element, oven is still not heating
You may still have a bad Electronic Range Control (ERC). This is your timer that you mentioned. The oven is controlled by the ERC. There is a separate circuit for the BROIL and BAKE functions. Does the BROIL element still work? Or, are both elements not working? You may want to double check all your connections from the element to the control board as well. Sometimes the wire lugs can oxidize and not make good contact. Check the ERC to see if there any obvious signs of failure. Burned components are common. These boards are considered "non-serviceable" and usually requires replacing. You can attempt component-level troubleshooting if you are savvy with electronics. There's usually a basic block diagram that comes with your appliance mounted somewhere inside the operator console or on the back panel of the range.
The ERC for your range would cost in the neighborhood of about $100 - $140 to replace. Prices will vary between model versions and will also depend on where you get it. It is a very simple repair job if you wish to pursue this yourself. I can give you step-by-step instructions if you need further assistance. I hope this helps you.
PS The reason all your surface elements still work is because they are controlled by infinite switches behind the control knobs. There is a separate switch for EACH burner.
12/23/2019 10:29:04 PM • Frigidaire... • Answered on Dec 23, 2019
0answers
Fef352awc
Be the first to answer 12/26/2017 12:57:03 PM • Frigidaire... • Posted on Dec 26, 2017Be the first to answer
0answers
2answers
I'm getting an F9 error, how do i reset it
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$#%@#$%
11/26/2015 5:24:54 AM • Frigidaire... • Answered on Nov 26, 2015
How to replace EOC?
Good Afternoon Friend, I understand you want to know how to replace the EOC in your Frigidaire range, model# FEF352. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the EOC with ease. Hope this is helpful. -Best Regards- WP
7/10/2014 6:00:07 PM • Frigidaire... • Answered on Jul 10, 2014
Getting F10 on oven
Good Morning Kathy, this is Z. Thank you for allowing me to assist you! If you are receiving an error code F10, it typically indicates that your Frigidaire range (FEF352) has detected an issue with the runaway temperature (overheating). Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (Electronic Oven Control) will need replacing. Hopes this help!
4/1/2014 1:15:29 PM • Frigidaire... • Answered on Apr 01, 2014
Oven won't shut off
Good Afternoon J, this is Z. I'm happy to assist you! If you are getting an error code F2, it usually means that your range is experiencing a communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) system. I would recommend, however, running a quick test to ensure that this is not a false error code. You do this by resetting your oven by flipping the breaker or unplugging it for approximately ten minutes. If resetting your range does not correct the issue, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
3/12/2014 2:07:57 AM • Frigidaire... • Answered on Mar 12, 2014
Lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
11/14/2013 9:26:26 PM • Frigidaire... • Answered on Nov 14, 2013
7answers
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
5/1/2013 9:15:52 PM • Frigidaire... • Answered on May 01, 2013
Cleaning
Hello Scott Gerken - I understand you are seeking instructions on how to clean your oven. I have located the manual on the manufacturer website. Hope you find all the data that you need and let me know if you need further assistance.
3/26/2013 4:01:14 PM • Frigidaire... • Answered on Mar 26, 2013
Donot work disple
What exactly is your concern with the unit? How is it not working?
12/31/2012 4:11:23 PM • Frigidaire... • Answered on Dec 31, 2012
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
12/26/2012 9:30:26 PM • Frigidaire... • Answered on Dec 26, 2012
FRIGIDAIRE OVEN BEEPING ERROR F 31 MESSAGE
Hello parmantal - Typically error code F31 indicates that the unit has a shorted probe connection problem. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and this will usually clear most false codes. If it proves to be ineffective, contact a professional to move forward accurately. The technician will need to check the resistance and/or harness between the EOC and probe connector. Depending on the diagnoses part(s) will need replacing.
12/20/2012 3:51:06 PM • Frigidaire... • Answered on Dec 20, 2012
Frigidaire crown series electric stove just delivered.
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
10/24/2012 1:32:32 PM • Frigidaire... • Answered on Oct 24, 2012
My stove says error 3
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
10/23/2012 2:55:44 PM • Frigidaire... • Answered on Oct 23, 2012
Frigidaire FEF352 Electric Kitchen Range Logo
Popular Tags
159 questions posted
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
getting f10 oven
  • Kitchen Ranges
