20 Most Recent
Pentax K100D Super Digital SLR Camera Questions & Answers
How do you change the shutter speeds on an pentax
You can't.
In Auto Pict mode the camera selects the best of the pre-set Scene modes for the photograph which you're about to take. It's basically a variation of fully automatic mode, so the camera selects everything for you.
Auto Pict and Auto are designed to let anyone pick up your camera and take a fully automated snapshot without needing to worry about what settings to use.
To alter the shutter speeds you need to select an appropriate mode such as shutter priority or manual.
My Pentax K100 DSLR is
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
I BOUGHT A PENTAX K10D
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
I was just wondering if you can take a photo
No... that camera (same as mine) does not have that feature.
Practice viewing the picture as soon as you take it. You'll get used to it.
If you want to "test" the shot and not save the pic, then instead of pressing the shutter switch, move the on/off switch past the "ON" position (it is spring-loaded and will return to the "ON" position).
Blurry pictures with Pentax K1000
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Glen
Why does it take so long to show to the photo after I press the shutter button?
The picture displays after the file has finished saving - if the speed of your SD card is slow, it can take quite a while before the picture is displayed. It also takes a while (up to a minute or more) if the shutter speed is low and the picture is mostly black (taking nighttime moon shots for instance).
Try using a better quality (higher speed) SD card.
Why isn't my K100D Flash not working?
please ensure that you've not used the camera for more than the advised amount of time by the manufacturer. Also, you can attempt to use the same brand/type of batteries as was including with your camera when you got it. Some manufacturers put internal fimware/software restrictions on their devices. For printers, this would be done for cartridges and in the case of your camera, it would be for batteries.
Lastly, I would check that your sd card isn't full before calling Pentax to refer you to a repair shop.
Thank you.
Pentax Espio 60S "E2" error
Hi for anyone reading this! My 60s was just flashing with this but I fixed it. Took the batteries out, swapped them and that didn't work. Tried to put the old ones back in a few minutes later and then it was fine! Just fiddle around with it. Hope this helps.
