20 Most Recent
Sony Cyber-shot DSC-T2 Digital Camera Questions & Answers
Free software download
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
I have Sony DSC T2.
hi i had the same problem
just go to HOME option
then MAIN SETTING
then click on the initialize option
and reset the factory setting
it resolve my problem
hope it will solve your problem tooo
Shaking and blurry pictures
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Vibrating sony cybershot dsc t2
Do I need to install software to copy the files
Cameras come along with software cd which will help you acquire the images from camera onto pc.
The software installation is easy and just a 1 time process. Next time onwards, you can just connect your camera through a USB cable and start the camera, the software gets started automatically recognising the camera and uploading pictures and videos to your pc.
Picasa from Google can do the same task if you don't find the software cd which came along with your camera.
Could sony dsc t2 as webcam ?
http://esupport.sony.com/perl/model-....pl?mdl=DSCS60This is a link to the instructions.
Just connect it to your pc and put into video mode. Then open Yahoo
messenger or MSN messnger. Use the menus in IM to activate it
or put a TV card in the computer and connect it to the coax in
Go here for the software you will most likely need:
www.filebuzz.com/.../
Sony_
Cybershot_
Webcam_And.../1.html
I want to view downloaded pictures from the
If you continue on this quest, you will be setting your camera up for future problems. This is supposed to be a one-way street...from camera to computer...not the other way around. Sure, it may work occasionally but your camera will become problematic eventually.
Internal memory problem
Hi!
The memory chip is bad, T2 have factory bad memory chips. Hi!
The focus is stuck. Contact your local Sony service center and see if they will repair it for free or at least give some kind of discount, as this is a factory fault. I know it as I work in a Sony service center.
Hope this helps!
Tom
