20 Most Recent
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Questions & Answers
My box sagem pvr 6240 stop suddenly and started to flashing er09
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
PVR says HDD not detected.
Disk may have failed or become corrupted. If it's a few years old, its PSU capacitors are probably failing. This is repairable, but you may lose your recordings.
I have installed A Sagem DTR67250T 250gb with the
I am also getting his p603 error on my DTR67250T. I saw on another site that it indicates a problem with the power supply and should contact Sagem Technical Support on 0845 0900316 to get a new one - said it would be 10.
