20 Most Recent ViewSonic NX2232w TV Questions & Answers
0answers
0answers
My picture on my TV
athacker,
This is a result of the aspect ratio being set to the wrong setting for what video source you are watching. Go into your menu and select picture>aspect ratio>normal. Then play with the five different modes to maximize the picture for the source you are watching.
I hope I was able to help. Please rate this answer if I was able to do so.
Thanks,
-Chris
4/7/2011 2:16:23 AM • ViewSonic... • Answered on Apr 07, 2011
ViewSonic NX2232w 22" monitor. Model
This kind of problem usually caused by a cold solder of components at the boards.You need to open the back cover of the TV and have a visual inspection on the boards.
here are the boards to check.
1.power supply board -this board is where the power cord is connected use a soldering iron to resolder all the possible loose board components.check also all the connectors/cables be sure it fits the socket and nothing is loose.Replace also any bulging capacitors use capacitor of the same rating.
2.The inverter board- this board is a high voltage board.The power input is 24 volts DC and the output is 100-200 volts be careful not to touch them during power on.The usual faulty here is the wiring connectors just re tighten the connectors and solder the connector terminals.
3/13/2011 9:35:09 PM • ViewSonic... • Answered on Mar 13, 2011
Osd time out?
OSD= On Screen Display. That feature keeps the information such as channel,time, ect.. for a length of time that you choose in the menu on the screen. Some sets let you change the color of it and also the background.
11/10/2009 3:59:30 AM • ViewSonic... • Answered on Nov 10, 2009
Sometimes the Viewsonic Nx2232W LCD TV goes into a
Press the Menu button, go to Option, then select Memory Recall.
8/29/2009 4:31:43 AM • ViewSonic... • Answered on Aug 29, 2009
My viewsonic nx2232w moniter just one day stopped
The problem sounds like the Power supply module to start with.
7/13/2009 6:30:17 PM • ViewSonic... • Answered on Jul 13, 2009
5answers
Why is my vizio tv's picture black and white?
it could be your flux capacitor is out. you might need to plug it in goto menus and check to see if ur runnin 21 gigawatts if not leave it plugged in and off for two days and it should refresh it
12/29/2022 9:16:23 AM • ViewSonic... • Answered on Dec 29, 2022
3answers
Does anyone have a manual for a Viewsonic Remote RC00315P?
Full instructions and codes here. For what it's worth, no one buys universal remotes these days, you buy a facsimile remote which is an exact copy for the television model you have. www.remotes.com. https://universalremote.codes/viewsonic-tv/ ..
10/27/2022 7:17:30 PM • ViewSonic... • Answered on Oct 27, 2022
2answers
How can I unlock osd on my TV viewsonic n2011
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds. http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
3/2/2022 5:27:24 PM • ViewSonic... • Answered on Mar 02, 2022
ViewSonic NX2232w TV Logo
27 questions posted
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Televison & Video
Most Popular Question
osd time out
  • Televison & Video
