20 Most Recent
Astar LTV-19BG TV Questions & Answers
Clor stripes on screen. Can not turn off tv unless
The color stripes can usually be fixed by opening your monitor and re-seating your lcd screen. The alignment tabs often slip on these generic models, pinching off the liquid lcd before it can reach the screen. Your other problem is caused by an inferior infrared receiver led. These can be replaced with a generic infrared receiver from radio shack. There are only 2 to 4 pins that need to be de-soldered to fix this. Many ppl think that the remote has drifted off frequency and needs to be dialed back in, and this simply isn't the case. Replace that led and your remote will work perfectly again.
I have an astar 19
Try to reset to factory defaults. Looks like the V-chip is stopping you and you may have a panel problem also...
My LTV only has sound
Please intimate exact model and brand of your TV to check its schematics for no picture problem.
Schematics and parts vary / different in models.
Hit "add a comment" button to reply.
Thanks.
If you still have your 19" TV and needed to resolve these problem?
Please call 323-767-6030 and I will help you go through the trouble shooting, with you.
White picture.
Sounds like you have the White Pattern turned on. Find your documentation for your TV and look it up. Should be an easy fix.
ASTART LTV-26HBG
Are you still having these connection problem? Please call me at 323-767-6030 and I will go through it, with you.
Thank you,
Ivan.
NO PICTURE FOR TV
First turn on your DVD player and keep your DVD playing. Then set your TV in to AV1 (the yellow, red and the white cable) connecting in the back of the TV. Any question call 323-767-6030 and I will go through it, with you.
Thank you,
Ivan.
CUTS OFF
If you TV is completed off and no power then you need to check the AC adaptor. I just wondering the intercate light is still on?
Any question please call me at 323-767-6030
ASTAR LTV 19BG WON'T TURN
If you still have your defective TV and needed to resolve? please call me at 323-767-6030 I know all the Astar model TV.
I need a c
The AC adaptor that you needed is Astar right?
Please provide the model of your TV. Call me at 323-767-6030.
