20 Most Recent Dynex DX-LCD37 TV Questions & Answers
What is the problem you faces with this set? If you wish to get some details; visit the site linked here. Pull up older posts.
Dynex DX-LCD37... | Answered on Dec 06, 2017
Time Warner has about 8 different remotes. I have the UR3-EXP remote and the Emerson code 096 worked for me.
Dynex DX-LCD37... | Answered on Sep 06, 2016
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
Dynex DX-LCD37... | Answered on Sep 04, 2016
The sound PCB is not separate it is part of a larger board. I do not suggest the cost as it may not fix the problem. Just replace the TV.
Dynex DX-LCD37... | Answered on Aug 30, 2016
Just try a reset to this set, and check. If it do not help you, the main system control memory IC is faulty. Check and replace it. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dynex DX-LCD37... | Answered on Feb 25, 2016
Search Results
    [PDF]DX-LCD37-09-2 - Dynex Products
    www.dynexproducts.com/.../DX-LCD37-09-2_08-1430_ENGLISH_WE...
    Jan 15, 2008 - DX-LCD37-09-2 ... Connecting an antenna, cable TV, or satellite TV box . ..... Remember that children can become excited while .... Do not drop your TV or hitthe glass screen. If the screen breaks, be careful of broken glass.Missing: ball
    [PDF]DX-32L200A12 DX-37L200A12 DX-46L262A12 - Dynex
    www.dynexproducts.com/.../DX-32L200-37L200-46L262A12_11-1082...
    DX-46L262A12. USER GUIDE. DX-32L-37L-46L_11-1082_MAN_V2_EN.book Page 0 Tuesday, November 22, 2011 1:09 PM .... Using the on-screen menus . ..... CHILDSAFETY ... TV or hit, jolt, or press hard against the LCD panel. If.Missing: lcd37 ‎ball
Dynex DX-LCD37... | Answered on Feb 03, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dynex DX-LCD37... | Answered on Nov 24, 2015
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dynex DX-LCD37... | Answered on Aug 11, 2015
If there is no power LED lights up at its front panel, it indicates that the main power supply regulator board inside the TV has the fault. It do not works at all, or it do not get the AC mains power into it to work.
If the power LED at its front panel is lit, and the set do not power up by pressing the power button at the remote control; it is the symptom of a faulty main board.
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dynex DX-LCD37... | Answered on Jun 18, 2015
Universal remote at Job Lot @ $10.
Dynex DX-LCD37... | Answered on Jun 09, 2015
Do a re-tune to this TV, after a reset. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dynex DX-LCD37... | Answered on Nov 02, 2014
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Dynex DX-LCD37... | Answered on Jul 28, 2014
The fault is with its main power regulator board itself. SMPS section is not oscillating. It will be best to contact any service technician. For more information go to http://electronicshelponline.blogspot.com/
Dynex DX-LCD37... | Answered on Nov 26, 2013
That "Tech" is full of hot air, I have never heard of such rubbish! http://www.hdtvreview.com/pdf/dynex-dx-lcd37-09-02-manual.pdf
Above is your manual. have a look for your self. Now IF you can do Picture in Picture, then technically, there are TWO tuners, BUT one cannot work, and the other not, I do NOT know what that Tech is on about I suspect he is BSing you... If channels are Blocked, then it is maybe something wrong with the cable, or the strength of the signal, or something else, But there are NO "Tuners" that are going faulty, this is NOT how a TV receiver works.
Does this Dynex model have multiple tuners: NO If so, can they go bad : Yes, as could any electronic bit. maybe the ONLY tuner has faulted, but I don't think so. Tuners usually work, or don't. but still may pay to take to a professional and ask them to check the tuner?
Are the tuners replaceable: YES.
will the rest of the tuners eventually go out and I will end up replacing the TV:. NO, well depending if there is any fault, maybe.
Again I have never heard such BS, EVER.
Dynex DX-LCD37... | Answered on Nov 06, 2013
Dynex DX-LCD37 TV Logo
213 questions posted
Top Dynex Televison & Video Experts
Vitally Alcher
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
power surge caused dynex 37 lcd
  • Televison & Video
