20 Most Recent Frigidaire GLTF2940ES Front Load Washer Questions & Answers
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Frigidaire... | Answered on Jul 24, 2019
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
Frigidaire... | Answered on Aug 22, 2018
you will need to unplug the machine and take off the back panel and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and another one when you let the air out again if so then the small pipe where you took it from is blocked preventing the switch to work properly , unblock the pipe with a pipe cleaner or metal rod its normally full of soap goo return the pipe and close the back up and run the machine again eric
Frigidaire... | Answered on Jan 17, 2018
if you send me the diagram I can possibly give you the answer, as normally there is the driver pcb to consider or I will find you the best way to do it, please ask the web site for my email address as I don't know if Im allowed to publish it on this answer eric
It is replaced from the rear of the drum, beneath the pulley.
You need a bearing puller tool and some common sense.
Take photos as you work, that aids reassembly.
Frigidaire... | Answered on Jan 06, 2018
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Frigidaire... | Answered on Dec 05, 2017
Call Frigidaire and keep asking for someone higher up until you get results.
Frigidaire... | Answered on Nov 07, 2017
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Frigidaire... | Answered on Oct 04, 2017
You bought them in 2009 and it's 2017. That's 8 years later.
Frigidaire... | Answered on Aug 09, 2017
Grit in the inlet water valve.
Frigidaire... | Answered on Jun 30, 2017
Frigidaire GLTF2940ES Front Load Washer Logo
1,216 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
fix washer from stopping early not
  • Washing Machines
