20 Most Recent
Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB Buffer Mobile Bulk 250 GB SATA Hard Drive Questions & Answers
I have bought toshiba satellite
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
6/21/2011 6:04:12 PM •
Toshiba...
Answered
on Jun 21, 2011
I have removed the MK2546GSX. What can I connect
You should be able to plug a SATA connector cable in to it and plug that in to your desktop PC board and there is power cord adapters. I do it all the time when i am repairing them.
2/5/2011 7:39:48 PM •
Toshiba...
Answered
on Feb 05, 2011
I'm getting a popup "windows
Modern disk-drives have built-in performance-counters and self-diagnostic capabilities.
These 'SMART' disk-drives can tell when the disk-drive is not performing "optimally";
it's a sign, as Windows indicates, that the disk-drive is *SOON* to completely *FAIL* to work.
Backup your files (and E-mail and contacts and music) to DVD-recordable media, or to an external file-storage system. Then, on another computer, "test" to ensure that you can read that backup copy, before you do anything to the "original" files.
Then, buy a replacement disk-drive, install it, and reinstall Windows onto it,
reinstall your anti-virus, reinstall MS Office, run Windows Update several times,
and finally reload your files from your "backup" device.
11/29/2010 8:44:34 AM •
Toshiba...
Answered
on Nov 29, 2010
Well me cd dvd romdose not work well the drive
Please check the connection inside maybe it is just loose. If that is SATA connection that is prone to disconnection but if that is IDE cable inside maybe cable loose contack. Try to open the PC and then pull and insert the cable firmly. Restart the computer.
1/27/2010 5:33:27 AM •
Toshiba...
Answered
on Jan 27, 2010
Electronic
Warranty 1 year (from date of purchase)http://storage.toshiba.com/storagesolutions/pc-notebook/mkxx59gsm-series
Mk 2559 GSX
I have wipro laptop with thoshiba hdd.when i try to install windows it shows no hdd deteted.please help
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
