click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives. Data Recovery - Recover your lost data Available in Live CD to run offline Recover accidentally deleted files in your hard drive Recover data from RAW Drive(partition table or file system is damaged) Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives" Drive Dumper - Backup your hard drive Available in Live CD to run offline Available to run on Windows Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition) For data rescue, backup, migration, or computer forensics etc. Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks) Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives" Windows Password Cleaner Available in Live CD to run offline This is a utility to blank the password of any user that has a valid (local) account on your Windows system. You do not need to know the old password to blank the password. Support Windows NT/2k/XP/Vista Support IDE/SATA/USB Hard Drives hope it helps
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps you
If your computer came with a motherboard disk the drivers could be on it.Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.Hope this helps.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Hope it helps.
253 questions posted
39 Questions
6 Questions
7 Questions
