20 Most Recent Sennheiser CX 500 Consumer Headphones Questions & Answers
The chance of both speakers going bad at same time is remote. Your ipod is at fault and has something wrong with its output circuits. Check to make sure that there is no muting circuit inadvertently turned on.
Sennheiser CX... | Answered on Jun 13, 2017
Two reasons are possible , first it can be from the source , so try the headphone on another device , increase volume and see if the noise persists. if so the headphone has problems.
Now this can be due to faulty earpiece speakers or poor connections within the flexible wires to the jack.
If the noise is evident on only one side then the headpiece must taken out and confirmed.-- a rather tough job to **** open to get access to the earpiece.
The replacement units are available only with Sennheiser but the cost must be taken to consideration.
Sennheiser CX... | Answered on Apr 23, 2011
Is it a mechanical or an electrical connection?
Sennheiser CX... | Answered on Oct 03, 2009
Hello Timothy, the microphone has a 3.5 mm connector, which has a thread, you must unscrew this thread and you should be able to exit
Discuss the type of connector you have
I hope you can solve the problem
Greetings Franco Dosil
Hola Timothy, el microfono tiene un conector de 3,5 mm, que tiene una rosca , debes desenroscar esta rosca y tendria que poder salir
Comenta el tipo de conector tiene
Espero puedas resolver el problema
Saludos Franco Dosil
https://assets.sennheiser.com/global-downloads/file/8949/SK_100_G3_Manual_12_2016_EN.pdf
Sennheiser Audio... | Answered on Jun 21, 2019
Hi David, comment that cables are wrong in the transmitter, to try to find the best possible solution
I wait your answer
Hola David, comenta que cables estan mal en el transmisor, para tratar de encontrar la mejor solucion posible
Espero tu respuesta
https://www.fullcompass.com/brand/sen-sennheiser/replacement-parts
https://en-us.sennheiser.com/accessories
http://www.hifiheadphones.co.uk/spares-accessories/sennheiser-spares.html?currency=EUR&dir=desc&limit=5&mode=list&order=name
Sennheiser Audio... | Answered on Jun 07, 2019
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output
the options that I suggest are,
1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment,
2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier
I send you links to the products that are sold in my country
I hope you solve your concern
This is the headphone amplifier
This is the optical fiber to audio converter by RCA L and R
Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica
las opciones que te sugiero son,
1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo,
2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares
Te env?o links de los productos que se venden en mi pa?s
Espero logres resolver tu inquietud
este es el amplificador de auriculares
Este es el conversor de fibra ?ptica a audio por RCA L y R
Este es el amplificador de auriculares
https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM
This is the fiber optic to analog audio converter
https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
Sennheiser Audio... | Answered on May 01, 2019
Hi Edgar, it is important that the receiver works, because there is a dialogue between the transmitter and the receiver to confirm that they are on the same frequency, that is why the transmitter is blinking, you should repair the receiver and look for the frequency or channel that the transmitter is found and it will stop flashing
Hola Edgar, es importante que el receptor funcione, porque hay un dialogo entre el transmisor y el receptor para confirmar que est?n en la misma frecuencia, por eso es que el transmisor esta titilando, deber?as reparar el receptor y as? buscar la frecuencia o canal que se encuentra el transmisor y este dejara de titilar
Sennheiser Audio... | Answered on Apr 15, 2019
You question contradicts
I can get sound out of the right side only.
Why no sound from right side?
Usually with headphones, it is a broken wire as they are very fine. Remove the ear pads and then get inside them. Or return them for service.
Sennheiser Audio... | Answered on May 06, 2018
Sennheiser CX 500 Consumer Headphones Logo
13 questions posted
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sennheiser Audio Players & Recorders
Most Popular Question
sound fades out both earphones
  • Audio Players & Recorders
