20 Most Recent Frigidaire FEX831C Stack Electric Laundry Center Questions & Answers
there is a clear hose running up the left front of your machine that goes to a pressure switch, either the hose is clogged, has come loose , or the pressure switch is bad
Frigidaire... | Answered on Dec 21, 2014
yes the tub could be replaced here are the part numbers
INNER TUB 131370400
OUTER TUB 131557201
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Frigidaire... | Answered on Aug 14, 2011
Here is a link to a exploded diagram of your machine and all the parts for it.
Frigidaire... | Answered on Nov 28, 2010
You probably have dry bearings from all the heat over the years. Unplug the unit and remove the back to expose the bearing and shaft. Using a light oil such as 3-in-1 squirt oil into the bearing and let it soak in. Do this several times and keep a rag under the bearing to catch any excess oil. Odds are that with a little lubricant the dryer will quiet down and work fine for many more years. This would also be a good time to clean any lint and dust bunnies out of the unit. Reassemble and test. You should be good to go. Let me know if I can be of anymore help.
hardrocko
Thanks for using FixYa
Frigidaire... | Answered on Feb 20, 2010
You may have one of several parts malfunctioning. If the water level sensor isn't working or the water solenoid sticks, this will happen. Let it fill and when it is at a point where it should shut off, check for voltage at the water solenoid (should be where the hoses hook up) If there is voltage there, the sensor is suspect. The sensor is behind the knob or buttons that get set for the load size. There is a tube running down into the tub from the sensor. That could be blocked. Otherwise, the sensor itself is probably your best bet.
Frigidaire... | Answered on Dec 18, 2009
unplug it and count to 10 and plug it back in.
If that doesn't work, remove the drain hose from its clips and lower the hose into a bucket. The unplug it and plug it back in. The water level switch also controls the door lock.
Frigidaire... | Answered on Oct 27, 2019
Its possible, the water valve will be energised to allow water to come in. The only way to confirm is to pull the fridge out and see if the noise is coming from where the water hose would normally be connected.
Frigidaire... | Answered on Oct 19, 2019
first try moving your drain hose higher it can cause this problem
Frigidaire... | Answered on Oct 04, 2019
Unplug it for 5 minutes. If that doesn't work, you may need to empty it of water by lowering the drain hose into a pail lower that the door.
Frigidaire... | Answered on Sep 14, 2019
Washing Machines Logo
18 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
wash tub
  • Washing Machines
