20 Most Recent
Philips MCD288/37 DVD Micro Theater System Theater System Questions & Answers
How to eject cd manually
i think u dont have any choice other than going to your laptop company server around you.....and he may fix it.........
4/10/2012 7:29:55 AM •
Philips...
Answered
on Apr 10, 2012
LG HT353SD?
open tray
0 0 0
then appears a screen asking for region, put 0 for free region, then press pause.
done
7/2/2011 3:10:55 PM •
Philips...
Answered
on Jul 02, 2011
HI THERE I GOT THE PHILLIPS MICRO DVD HOME THEATER
1. Ensure there is No Disc in the player
2.Press Remote Control (RC) "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not
entering the sub-item );
4.Press RC numeric key sequentially 811502(entery code,no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is
all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
2/11/2011 7:02:25 PM •
Philips...
Answered
on Feb 11, 2011
Remote control works, but the
Hello
Have you checked the remote control for its infrared light emmission?. If your remote controls infrared emmission is ok, then the fault must be in the remote sensor inside your micro theater system. This part comes just behind its infrared window. It is a three terminal device called IR sensor. You just check your remote handset once more. If you have a cellphone with camera option, put the phone on camera mode, and place the remote hanset in front of the camera lens, at about a feet away or so, and push each button on the remote hanset. If infrared rays are emitted, the camera will sense it, and you can see its image on its screen. If it is ok, then replace the remote sensor stated above, with a same type and number. Its number will be printed on its body [Laser marked]. Replace it with exact type and number, as it is a critical part. OK.
12/12/2010 5:27:43 PM •
Philips...
Answered
on Dec 12, 2010
