20 Most Recent
Dell Latitude D630 Notebook Questions & Answers
My Dell Latitude D630 has a blank screen.
it seems to me that the hard drive drivers are not working on the hard drive so for it is time to replace the hard drive and reinstall windows.I had the same problem with the sound card, wifi one time and then the screen keep going blank and I replaced the hard drive and reinstalled windows and now the computer works just fine.
Unidentified Network Windows 7 ??
You need to uninstall the ethernet driver and then reboot. Then use Wifi and go to the PC manufacturers website and download the latest Ethernet drivers. Install and reboot.
Computer wont turn on
There is a possibility that your computer may have been too hot which was why it froze. You can also try reinstalling your gpu driver as well as try to close down applications in the background because if you have too many things opened in the background at once it can slow things down.
How to close down applications with task manager
How to close program using Task Manager
Where is the LCD cutoff switch located ?
Both the D620 and the D630 use the same keyboard.
The picture below shows the keyboard.
Hold down the blue Fn key at lower left, and then press F8 while holding down Fn. Press F8 multiple times until the screen returns.
If that fails, the ribbon cable connected at the main board from the screen may be loose and removing it, then reconnecting it, is the most likely solution.
ixquick proxy com
How to reset the system bios dell latitude d630
Anonymous,
If you need help resetting the bios password on your D630 you will need to contact Dell Support by phone. They will verify ownership of the system and then provide you with information on resetting your bios password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
How do I see if Video card is not working on a Latitude D630 lab top
Just because you plugged in an external monitor and didn't see anything doesn't really mean anything. Sometimes you won't see anything even if that laptop is working. Some have to be set in windows some you may have to use the one key on the keyboard. I know you said you replaced the ram but if there's 2 slots take 1 out and try it like that. If that don't work put the ram in the other slot and try it. Also use a flash light and point it at the LCD and different angles to see of you see any display. Laptops don't have video cards but the do have onboard graphics chips.
How do I find the MAC address for my laptop
Anonymous,
To find the mac address on your computer follow the steps below.
Option 1
1) Click the Start Orb at the bottom left of your screen.
2) Type ncpa.cpl into the search box and press ENTER.
3) Right-click your Local Area Connection and select Status.
4) Click Details and the Physical Address is your MAC Address.
Option 2:
1. Click on the Windows Logo in the bottom left corner.
2. In the search box, type in cmd and press enter.
3. In the command prompt, type in getmac (with no spaces) and push enter.
4. The MAC address is labeled Physical Address
Thank You,
Dell-Jesse L
#iwork4dell
Hi..the thing is my laptop has no sound..in some
Hello
You will need to reinstall the drivers from your cd or dvd that came with the notebook.
If you no longer have the cd or dvd you can get and download drivers from Dells website.
First make sure that your sound is configured correctly in control panel/sound options.
Dell d630 blank screen 2 beeps
Tom - I thought the video adapter was part of the motherboard on a D630. How are you fixing a bad video adapter and 'often without parts'? I only asking because I have a D630 that I believe has a bad video adapter and would like to resurrect this PC. It is in otherwise great shape.
Thanks in advance. - John
