20 Most Recent Acer Aspire 4520-5582 Notebook Questions & Answers
2answers
HOW TO TURN ON WIRELESS CAPABILITY?
First try using the FUNCTION key combination "Fn" then F2
Next if this is not working then,go to my network places(To go to my network places:my computers left handside you wil get it) click it, then click on the option view network connections, then right handside click on wireless network connections, then right click and select properties, you wil get a window in that select wireless connection and check whether the first option is ticked or not.
Cheers
4/20/2019 11:37:19 PM • Acer Aspire... • Answered on Apr 20, 2019
I can't turn on my wireless LAN. There is a
Try to restore your PC to the backdated point in SYSTEM RESTORE menu in control panel. Then try to switch ON wireless again. If this step does'nt work it means your Hardware (wireless adapter) is malfunction. Replace with a new one (USB Wireless adapter)
1/10/2018 8:13:10 AM • Acer Aspire... • Answered on Jan 10, 2018
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
9/7/2017 1:42:09 AM • Acer Aspire... • Answered on Sep 07, 2017
WANT TO RESTORE ACER ASPIRE 4520 TO ORIGINAL
Hello, If your system is capable of doing a Recovery via Hidden Partition on Hard Drive, you can access it by Pressing Alt + F10 and choose Recovery Option.
5/11/2017 11:58:26 AM • Acer Aspire... • Answered on May 11, 2017
How to turn on wireless
1. On your laptop turn ON the wireless switch, it may be on the side or in front.
2. After turning ON the wireless switch the wireless light will turn ON
3. Click on "Start" and click on "Run" type "ncpa.cpl" and click "OK"
4. "Network connections" window will open
5. In "Network connection" right click on "wireless network connection" and left click on "view available wireless networks"
6. You will get a window showing all the wireless networks in range
7. Click on the wireless network you want to connect to and click "connect"
8. If it is a secured wireless network you will be prompted to enter the password or else you will be connected directly
9. If it prompts you for a password, type the password and reconfirm the same in the 2nd box and click connect.
10. After a few seconds you will be connected to the wireless network.
12/15/2016 8:37:52 AM • Acer Aspire... • Answered on Dec 15, 2016
2answers
I have 38 viruses
On the 2nd Tuesday of every month, Microsoft releases a free tool to address virus infections. The tool is called Microsoft Windows Malicious Software Removal Tool. It is usually downloaded in an infected computer's hard drive but if this cannot be done, the tool can be loaded into a USB stick or thumbdrive on another computer then inserted into the infected computer's USB port to be run. Microsoft also has online tools to scan and remove malware. For more information and download go to .... http://www.microsoft.com/security/pc-security/malware-removal.aspx
5/7/2016 2:10:29 PM • Acer Aspire... • Answered on May 07, 2016
2answers
Acer aspire 4520 updaed to windows 7 SP1 i have tried with so many driver for wlan atheros rg5000eg but windows says error code 10 device cannot start, Could you help me to solve this?
I suggest you plug into the internet using an ethernet cable and then open the device manager and ask it to search for an updated driver. I just had to do that with my Windows 7.
3/30/2016 2:45:44 AM • Acer Aspire... • Answered on Mar 30, 2016
Acer aspire 4520 wlan drivers
To help you install wlan drivers for your Acer Aspire 4520 Notebook, please find the below given link and follow the instructions to download and install Modem driver and Chipset driver: http://www.acer.com/ac/en/US/content/drivers GuruAid.com
3/29/2016 7:32:16 AM • Acer Aspire... • Answered on Mar 29, 2016
Over driven color
could be the wrong driver. or try going into your control panel and set from display settings.
4/5/2015 10:28:23 PM • Acer Aspire... • Answered on Apr 05, 2015
Is there a reset button on a lap top
mine is f5.
4/5/2015 7:26:17 PM • Acer Aspire... • Answered on Apr 05, 2015
How Do a factry reset to my Acer Aspire 7741Z-4433 Laptop To Be as New?
goto your start menu and typ in restore it should give you all you need to know
3/29/2015 8:25:20 PM • Acer Aspire... • Answered on Mar 29, 2015
Why aspire 5520 TPM driver won't start ?
try uninstall the driver and then reinstall the driver
3/29/2015 7:19:28 PM • Acer Aspire... • Answered on Mar 29, 2015
No wi-fi on acer laptop
make sure the drivers are installed.and make sure your wifi is turnd on.
3/29/2015 7:03:03 PM • Acer Aspire... • Answered on Mar 29, 2015
2answers
Fix backlihght
you need to take all the small screws from around the edge of the screen then very slowley pull it away.then pull the screen very slowley away from its case and behind the screen you will have ribbins on the back of the screen pull them of, then you take of the converter thats at the bottom the screen,and to put it back just do it the same way you took it off.
3/29/2015 7:01:40 PM • Acer Aspire... • Answered on Mar 29, 2015
Problems connecting my dell computer to the internet dell inspiron 1720
plug in the ethernet cable or cat5 into laptop. then go to the keyboard and click on the windows key. go to computer then with the right mouse botton click it. select manage. in the new menu. select manege devices. look for the wifi. remove it. refresh. it will remove it. reboot pc. it will reinstall new driver for the wifi. if it does not work. wifi card is busted. on my own experience it was the wifi card no good. good luck
3/8/2015 10:11:51 PM • Acer Aspire... • Answered on Mar 08, 2015
2answers
My Acer aspire 4520 windows vista laptop is
Hi there, this may work, try this. Take off laptop battery, remove power cord, turn laptop upside down. Just take off screws on the covers you see, which let you see HDD, Memory,Wireless card,.... , take off the cover or check on line for service manual for your specific model on how to remove the plastic cover/ covers, which is covering the CMOS battery which is some time wrapped up with yellow tape. Just remove the battery by holding on the white connector which attached to the motherboard with black and red wires. Gently pull from the motherboard. Now without the CMOS battery, connect power cord and turn on the laptop, it should turn on. Now turn off , remove the power cord, check voltage on battery , it should measure very close to 3volt (2.5 to 3.0 volt), otherwise get a new one, connect the battery, put back covers, and now you set a new password.
2/21/2015 6:09:39 PM • Acer Aspire... • Answered on Feb 21, 2015
2answers
WHEN I HAVE MY LAPTOP
Hi Tina,
Your battery needs a calibration, follow the instruction below to calibrate the battery.
  1. With Windows Vista, navigate to Control Panel > Performance and Maintenance > Power Options
  2. Click "Change Plan Settings".
  3. Set all tabs to "Never" underneath "On Battery" column.
  4. Click "Change advanced power settings".
  5. Set Sleep > Hibernate after to 0 or Never.
  6. Set Battery > Critical Battery Level to 0.
  7. Click on "OK", then "Save Changes".
This is the only time that we recommend taking the battery all the way down to zero percent. Unplug the ac adapter, and let the battery drain all the way down until the laptop shuts off. Then plug the AC adapter back in, and let it recharge to 100% or where it actually reaches. You may need to repeat the cycle 2-3 times before it actually reaches 100%.
Note: After the calibration is done, change the power options settings back to what it was as they will help you save power. Also, when a power source is available dont run the laptop on battery, it will increase the battery life.
Regards,
Shrey
8/17/2014 3:27:03 PM • Acer Aspire... • Answered on Aug 17, 2014
ACER PREDICTOR C5900
I think you mean a Predator? and again you are so proud of it that you want to tell the world you have one...No ! Whats the problem ????? Lol !!
7/26/2014 1:04:13 AM • Acer Aspire... • Answered on Jul 26, 2014
Turn off the wireless connection on windows 7 lenovo laptop
This is Acer, not Lenovo.
7/26/2014 12:14:18 AM • Acer Aspire... • Answered on Jul 26, 2014
Acer Aspire 4520-5582 Notebook Logo
676 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 4520 updaed windows 7 sp1
  • Computers & Internet
