20 Most Recent Toshiba Satellite A215-S5822 Laptop Questions & Answers
How to format a drive so I can reinstall windows
start the computer and at the same time keep the delete button depressed until the bios screen comes up in one of the tabs you will find format the hard drive do that then go to oot tab and change boot sequence from hard drive to cd as first preference open the cd and insert the disc close down the computer then restart and it will boot from the cd
11/17/2017 9:24:05 AM • Toshiba... • Answered on Nov 17, 2017
What is the upgrade for a 2.0 ghz cpu in this model?
talk wit your IT repair shop it may require a new bigger motherboard to take the bigger cpu chip
9/2/2015 10:52:38 PM • Toshiba... • Answered on Sep 02, 2015
3answers
Toshiba A215 bios password
This is a known bug on some Toshiba lappies - and one of the reasons I updated my A215 BIOS 4 times in the last few months!
Not sure if this is what happened to you, but...
Applicable Models: Satellite A100-ST8211, A100-SP471, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4014, A105-S4051, A105-S4094, A105-S4144, A105-S4034, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4211, A105-S4201, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4104, A105-S4074, A105-S4547, A105-S4334, A105-S4304, A105-S4294, A105-S4364, A105-S4344, A105-S4021, A105-S4031, A105-S4012, A105-S4011, A105-S4397, A105-S4374, A105-S4384, A105-S4022, A110-ST1111, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S4499, A135-S4498, A135-S4488, A135-S4478, A135-S4507, A135-S4487, A135-S4477, A135-S4467, A135-S4457, A135-S2396, A135-S2386, A135-S4637, A135-S4527, A135-S2356, A135-S2346, A135-S2336, A135-S2376, A135-S2326, A135-S4517, A135-S2306, A135-S4727, A135-S4677, A135-S4666, A135-S4656, A135-S2426, A135-S4447, A135-S4437, A135-S4427, A135-S4417, A135-S4407, A135-S2296, A135-S2286, A135-S2276, A200-ST2041, A200-ST2042, A205-S4617, A205-S4639, A205-S4618, A205-S4567, A205-S4577, A205-S4587, A205-S4597, A205-S4629, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S7468, A205-S7466, A205-S7464, A205-S4607, A205-S4578, A205-S4557, A205-S4537, A205-S4638, L35-SP1011, L35-S2194, L35-S2174, L35-S2161, L35-S2316, L35-S2366, L35-S2206, L35-S2171, L35-S1054, L35-S2151, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST1071, P100-ST9612, P100-ST9412, P100-ST7211, P105-S921, P105-S6002, P105-S6014, P105-S6054, P105-S6034, P105-S9337, P105-S6227, P105-S6217, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6024, P105-S9312, P105-S6004, P105-S6012, P200-ST2071, P205-S6297, P205-S6298, P205-S6247, P205-S6287, P205-S6257, P205-S6267, P205-S6237
Tecra A7-S712, A7-S612, A7-ST7711, A7-ST7712, A7-ST5112
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 1.40. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
BTW, I've heard that this only happens when you boot up on battery power.
Maybe you can confirm this...
3/26/2015 12:33:08 AM • Toshiba... • Answered on Mar 26, 2015
0answers
Manual a215-s5122
Be the first to answer 10/17/2013 9:45:07 AM • Toshiba... • Posted on Oct 17, 2013Be the first to answer
2answers
SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
WHAT TYPE OF HARD DRIVE DO YOU HAVE, IF YOU DO NOT KNOW, UNPLUG LABTOP REMOVE BATTARY, LOOK FOR THE DISC SHAPE ON A COVER 2-3 PHILLIPHS SCREWS REMOVE THE SCREWS, SCREW WILL STAY ACCACHED TO THE CLASTIC COVER, IF YOU STILL CANNOT SEE A NAME SHOULD BE A TAB OF SOME COLOR PULL JENTLY AND THE DRIVE WILL COME OUT THAN TURN OVER DRIVE AND YOU FIND NAMES NUMBERS AND LOTS OF GOOD INFORMATION FOR ME AND YOU TO KEEP RECORDS OF YOUR HARD DRIVE TYPE OF DRIVE DO YOU HAVE...
GO TO ADDRESS BAR AND TYPE IN
SMART FAILURE HAR DDRIVE
AND YOU GET ALL THE INGO YOU NEED ON THE SUBJECT.
IT CAN BE HARD DRIVE, THE BOIS ON THE MOTHER BOARD, THE SOFTWARE PROGRAM THAT WROTE ALL THE INFORMATION TO HARD DRIVE.
THIS IS A BIG PROBLEM FOR YOU
ROD THE CANDYMANGNADY
6/12/2013 10:40:35 PM • Toshiba... • Answered on Jun 12, 2013
4answers
Toshiba Satellite A135-S4447 wireless adapter not useable in windows XP
Well of course I do have to tell ya that downgrading from the original operating system which is Vista OS on your computer will cause alot of issues, Usually you will need to go to each and every manufactors website for each product and locate the driver yourself because every Computer Manufactor company will tell you that you should keep the windows operating system that came with the computer or they will not provide you any drivers, and they mean it, I tried downgrading from Vista OS to XP and had no drivers ... I would try going to the Wi-Fi adapter/card manufactors website and try to locate a driver. That is your bests bet Toshiba is not going to help any...especially if warrant is out of date...Let me know how it goes!
4/10/2013 4:16:07 AM • Toshiba... • Answered on Apr 10, 2013
2answers
Windows 7 detect hard disk failure in acer Laptop 5336-2524
The chances is good that the hard drive is faulty when Windows says that. The best is to backup all your information and get a qualified technician to test the hard drive properly and then to replace the hard drive if faulty.http://answers.microsoft.com/en-us/windows/forum/windows_7-system/windows-detected-a-hard-disk-problem/04a301bc-e063-429d-ac93-f8f4062e5d62If it is not the hard drive then it might be your hdd controller on the motherboard. If that is the case you will need to replace the motherboard. But a motherboard can be expensive. In that case you can get rid of the laptop and rather buy a new one.
1/14/2013 8:01:08 PM • Toshiba... • Answered on Jan 14, 2013
2answers
Shuts down
thank you for your response....I'm using Vista and the power seems to be on but the screen is down. I have to hold the power button down for 10 seconds to shut down then turn it back on to restore the computer. It is a Toshiba A215-S5818
6/12/2012 3:48:59 AM • Toshiba... • Answered on Jun 12, 2012
Satellite a215-s4757 won't boot after reassembly
BAD MISTAKE.NOW YOU WILL NEED TO OPEN IT AGAIN AND RESET ALL THE HARDWARE.
4/12/2012 6:11:38 AM • Toshiba... • Answered on Apr 12, 2012
Finding wireless drivers for satellite a215-s5822
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
2/19/2012 5:52:20 AM • Toshiba... • Answered on Feb 19, 2012
All i wanted was the administrator pass word of
Check my password solution at http://www.fixya.com/support/r5953318-reset_bios_password
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
9/26/2011 12:10:53 AM • Toshiba... • Answered on Sep 26, 2011
0answers
Get a new harddrive and clone the old one before it fully fails.
5/26/2011 3:07:18 AM • Toshiba... • Answered on May 26, 2011
I did not ask for advise I asked how to fix the
My friend Im here to please. But if i was you you i wouldnt touch it. I have two. They are Buggers to put back together.
4/7/2011 6:37:35 PM • Toshiba... • Answered on Apr 07, 2011
How do i go about changing the dc power jack? I
Your next step is to download the service manual from Toshiba. This will give you detailed instructions for disassembling your laptop. Luckily for you replacing the jack does not require soldering, it plugs in. The part can be found HERE for less than $5.00
4/6/2011 2:24:43 AM • Toshiba... • Answered on Apr 06, 2011
I cant reformat my tosihiba satallite A210
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
1/24/2011 5:36:26 PM • Toshiba... • Answered on Jan 24, 2011
Smart failure hard disk 4
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
12/20/2010 4:39:25 PM • Toshiba... • Answered on Dec 20, 2010
Toshiba Satellite A215-S5822 Laptop Logo
Popular Tags
83 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
wish adjust brightness level
  • Computers & Internet
