20 Most Recent
HP Compaq Presario F750US Questions & Answers
I AM STUDENT OF MBA
if you are looking for purchasing a new battery, contact any authorised computer hardware deale. they will provide you with one.
if you intend to repair it, you should loook for authorised notebook service centres present there. the nearest service proffesional coulde be located from the company website.
repairing a battery pack seems impossible.so i would suggest buying a new one
3/5/2018 1:07:32 PM •
HP Compaq...
Answered
on Mar 05, 2018
I want to buy a laptop
hello...G7 systems company has release very high quality configurised laptops at very less price compared to other company laptops...customer service and warranty period also good.for more details call me at :09480129287....i m from bangalore
for system configuration and thr price plase visit:
http://218.248.40.19/laptopcompare.html
7/10/2015 6:55:43 AM •
HP Compaq...
Answered
on Jul 10, 2015
Hp laptop 6730
he HP Compaq 6530 laptop series is the latest from HP Compaq.There are
four new laptops in the HP Compaq 6530 series.Each of these have
14.1-inch WXGA display (1280×800).They are namely HP Compaq 6530b, HP
Compaq 6535b, HP Compaq 6530s, and HP Compaq 6535s.
The b series are business series laptop which focus on mibility and the
s series laptops are the enhanced security series which have added
security features.
The b series laptops (HP Compaq 6530b and HP Compaq 6535b) has the
intel mobile processors with Intel Mobile chipset whereas the s series
laptops (HP Compaq 6530s and HP Compaq 6535s) has the AMD mobile
processor with AMD M780G chipset.
3/7/2015 11:31:40 AM •
HP Compaq...
Answered
on Mar 07, 2015
Synaptics touchpad not working properly
Hmm give this method a try.
Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases.
Good Luck !!!
2/21/2014 8:26:32 AM •
HP Compaq...
Answered
on Feb 21, 2014
I need a conexant smartaudio 221 driver for windows 7
Have you been to the Compaq/HP website to check your specific model for updated Windows 8 drivers? It's tough to know for sure...but "Base System Device" and "Coprocessor" are possibly parts of the motherboard chipset..and the SmartAudio 221 component is also likely built in to the motherboard. I would do a search on the HP/Compaq website, and possibly find the right drivers using their support tool...it may identify them based on your serial number. Make sure they have Windows 8 compatibility. If not, you may want to go back to 7 for a while until all the drivers can be updated for 8.
2/28/2013 12:58:53 PM •
HP Compaq...
Answered
on Feb 28, 2013
Factory settings on my laptop
It's usually F11 or Fn+F11 at the bios startup screen to enter recovery mode.
If that doesn't work, let me know.
9/22/2012 10:30:32 PM •
HP Compaq...
Answered
on Sep 22, 2012
Upgrade HP Compaq Presario F750US - CPU, GPU & RAM
You'll spend more money trying to upgrade this laptop then it would cost to just buy a better used one on eBay. Probably even spend more that it would cost to buy a new low end computer. Save yourself the headaches and time and buy a NEW laptop.
6/14/2012 4:39:34 AM •
HP Compaq...
Answered
on Jun 14, 2012
My Compaq Presario F750US Notebook PC power comes
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
10/20/2011 1:41:50 AM •
HP Compaq...
Answered
on Oct 20, 2011
File\windows\system32\winload.exe missing or corrupt
status:0xc000000f
do
You can do these procedure to correct the problem , Start in safe mode press F8 during boot up of your computer and select the C> prompt. Use the following commands: bootrec.exe /fixmbr and then bootrec.exe /fixbootand hit enter.
But after doing that procedure and problem is still there you really need here a operating system dis to correct the problem or a recovery disc for your computer that you can request from the manufacturer.
7/3/2011 9:57:34 PM •
HP Compaq...
Answered
on Jul 03, 2011
Hello, My Compaq Presario 750US will
The motherboard of your laptop might have encountered a short circuit. If you've already removed and reseated all possible removable parts and still get the same result, purchase a replacement motherboard or check if it is still under warranty.
Good luck.
5/17/2011 6:33:24 PM •
HP Compaq...
Answered
on May 17, 2011
