20 Most Recent
ASUS LCD Monitor Questions & Answers
Intermittent dropout on monitor screen
Check Monitor cable maybe even replace if not check graphics card and check monitor on another computer if problem still happens on second computer you screen has had it
Why can't I increase volume?
hi, don't know what your monitor is beyond ASUS nut I can tell you that, generally, monitor speakers are very quet on most monitors. In the years I have used a computer I have never had a monitor with decent speakers. I think it may be due to space limitations
Hook up speakers
Either use an HDMI cable, or run an addition audio cable from the computer to the monitor speakers. Google for the instructions specific to the monitor model.
Asus DVI and HDMI connection not working on monitor
Asus DVI and HDMI connection not working on monitor?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:
[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
Problem with windows XP and ASUS VE278Q Monitor?
When getting consistant a line that is covering the entire screen vertical or horizontal in any width, is most likely due to a cable or monitor hardware defect.
1.
No matter what cable you are using, then make sure it hasn't been damaged - Sometimes a small dent cause a huge defect.
2.
Try a similar cable or the same cable in another monitor.
3.
NEW PRODUCTS:
Never wait or hesitate to contact the manufacturers support or the store where you bought the product to get a replacement or refund (warranty). Don't use a lot of time trying to repair something that should have worked and which you don't have any knowledge about, it is simply a waste of your time.
I have the VE278Q which is connected by display
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
How to turn off aligment grid
When the allignment grit is on you just have to press the Menu button. It's 2 buttons right of the Allignment Grit button.
Monitor color fades in and out
If you can try hooking it to another computer, if the problem persists then it's probably the monitor. If it works correctly then a new video card may be in order.
Stretching problem
You need to change the properties of ur graphics and change its resolution and see what happends.
The properties may occur by right clicking on desktop and goto the graphics properties next move to advanced mode under graphics properties.
May this helpful to u and enjoy.
Change 720p 1080p
Are you using a Nvidia gfx card? If so, then go into the setup menu (comes with all Nvidia drivers). in the "screen size" menu, there should be a list of the supported screen resolutions. Do remember that the cable you use (HDMI, Display Port, VGA, DVI etc. ), also has an effect on the screen resolution.
Screens shows but then gos black
Confirm that all the input cables at the back are securely plugged at the rear of the screen and PC/output source and that the image source is switched on and displaying an image. This can be done by switching your PC on and waiting five mins. Then check that the power for the screen is on. If this does not work, then let me know
HDMI NO SIGNAL
It sounds that a firmware update is necessary. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
