20 Most Recent
ASUS M2N-VM DVI - Motherboard - micro ATX - GeForce 7050PV - Socket AM2 - UDMA133, Serial ATA-300 Questions & Answers
What means sb pwr
'SB' stands for StandBy. When the motherboard is connected to the power supply but not turned on the SB voltages are supplied to different parts of the motherboard. In some motherboards you are able to charge devices like Phone without powering on the computer, that's because of the SB.The SB in turn triggers other voltages used for the motherboard.
Hi i have an asus
sounds like your bios has corrupted.
if you know anyone with an eprom programmer they can remove the chip and re-flash it.
if this is the case there is no-other way to fix it.
ASUS M2N VM DVI trouble
You must replace the processor cooler, the fan on it has aged and it's no longer doing its job properly. And use a good thermal paste.
BTW that software was designed to notify you of the temperatures and nothing more, reinstall it immediately.
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
CMOS Checksum error.
the only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
