20 Most Recent
Sony E-reader Portable E-book MP3 Player Questions & Answers
Ways to get back your ex if he has a girlfriend?
Well,I am trying to show you
guaranteed ways to get your ex back.Reflect within the relationship this is with them boyfriend and enquire a few pre-determined questions to by yourself. Was he / she sweet in addition to kid? Performed he forget about your inner thoughts or injured you mentally, mentally or may be physically? It is advisable to find available if they are really worth a 2nd chance or maybe someone don't ever go here we are at.Win them back in addition to express ones genuine inner thoughts towards them by making him learn you absolutely miss them and they are always in every thought. If people ended the relationship, let them know people made a big mistake and from now on realize he / she were a fantastic person that had been perfect available for you.Bring in the good times you both spent together in past times. When he / she thinks of the fond memories of the relationship, he may consider acquiring you returning.Take factors slowly to help you to win his or her heart all over again by asking whenever you can become good friends. If he / she agrees to help, this need to be your possible opportunity to explain by yourself and look at what journeyed wrong from the relationship along with the mistakes of which turn the relationship sour. They may undoubtedly have something to mention as he may explain the way he felt around the failed marriage.Ask in the event he doesn't go to mind standing sometimes. This is a sensible way to spend longer with him to help you to ease towards you back with his life to be a girlfriend all over again. Visit places you both used to visit to so he'll reminisce around three days in the event the relationship seemed to be perfectly very good. If factors go fully smoothly after some time, go here we are at the primary place people met them at and enquire if he loves to be your own property again.Before making moves on your ex-mate, make sure that he seriously isn't already considered. If they are, respect them and his or her relationship by means of staying available if the item.Making effort you happen to be a superior girlfriend shows them you can be considered seriously instead of playing games in reference to his heart.When you and they have communal friends, learn he senses about people.Use the above mentioned tips, decide one action plan and have absolutely the guts to indicate him you actually believed him completely. He will likely be definitely your own property. Good Chance. Have hope in yourself by doing everything suitable and in its area.
My sony ereader PRS600is not charging... i pushed
1. Connect the Reader to a different USB port of the Computer.
2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp.
3. Disconnect the Reader and then press the RESET button.
4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly.
5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
How can i delete a book from sony e reader
On the PR-500 and the PR-505 readers it IS possible to delete a book without going through your computer. Go into utilities, select delete book, and when told to push the Mark button, which you don't have, push bookmark instead and wait.
My sony ereader has been
Hi!
Seems like your MAC goes into sleep mode, when this happens, the computer does not supply power to the USB ports to save power. When the computer does this, there is a big change that will drain out the battery of the Reader. You can try this:
1. Connect the reader to the computer
2. Hit the reset button while is connected for 3 seconds (Reset is located at the bottom of the unit)
3. Leave the reader charging for about 40 minutes then disconnect the reader and check the battery meter
4. If you can see that the reader took some charge then leave it connected for 2 hours or until the redlight goes off
Good Luck!
eBookBoy
http://digialreader.freeforums.org
My sony prs 350 ereader
Hi!
If the Reader is frozen, you can try the following:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
eBookBoy
I have the sony ereader
Looks like the reader is missing charge, try this:
1. Connect the reader to the computer and make sure a red steady light comes on, if not, then hit the reset at the bottom of the reader for 3 seconds and check if the light comes on now
2. Leave the reader charging for 15-30 minutes
3. Disconnect the reader and see if operational now, if still frozen, try the reset again and slide the power switch.
Good Luck!
eBookBoy
I charged a small sony
Hi nellvandenel,
Looks like the reader is missing charge. You can try these steps:
2. While Reader is connected, hit the "Reset" button at the bottom of the reader
3. Check if a red steady light comes on, if not, try the reset again
4. Leave the reader connected for 15-30 minutes to allow it to charge
5. Disconnect the reader and check if is operational now
eBookBoy
MY SONY EREADER ISNT WORKING
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
eBookBoy
digialreader.freeforums.org/
Sony pocket ereader frozen on
Hi shianto,
Because of e-ink screen technology the reader will display last page even if the unit is not charges it may display "full". Try this:
1. Connect the reader to the PC and check if a redlight comes up
2. If there is no light, hit the reset at the bottom for 3 seconds, the light should come on now.
3. Leave the unit charging for about 15-30 minutes
4. Unplug the unit and see if its operational now, if not you can try the reset again and the slide the power switch
eBookBoy
My ereader was low on
Hi marinaherman,
Probably the computer went into sleep mode while charging overnight. Try the follwing
2. Make sure the redlight comes on
3. If the light does not come on, hit the reset while reader is connected to the computer
4. Leave the reader charging for about 15-30 minutes
5. Check if reader unfroze and check battery metter
Hope this resolves the problem
eBookBoy
My pocket book, touchscreen edition
Hi fidelia6,
This happens when the reader is missing charge, you can try this:
1. Hit the reset button at the bottom of the reader for 5 seconds
2. Connect the reader to the PC and check if the redlight comes on at the top, if not try the reset while connected
3. Leave the reader charging for 15-20 minutes
4. Disconnect the reader and see if full operational now
eBookBoy
www.digitalreader.freeforums.org
