20 Most Recent
Samsung YP-U2JZW MP3 Player Questions & Answers
I can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
- When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
- The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
- Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
- The player does not appear in My Computer.
- Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
- When you use the player on another PC or laptop, it works flawlessly.
- Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
- Go to Samsung.com, enter in the model u have in the search area and then go to support, this should fix the problem!
Turns off automatically
Plug it in and charge it for 3 hours, if it does not say fully charged
or dies quickly after this, then the battery is no good.
You could try this, turn on till dead, wrap in newspaper, place in zip lock bag, place in freezer for 2 days, take out let sit for one day in a warm area,
charge for three hours and see if it holds the charge.
How do you take music off of your mp3 and save it
Go to Windows Media Player. Plug your Samsung in with your usb cable. Then when Windows Media Player is open go to the sync tab. Then you find your samsung on the left side and click it. Then you go to songs. Then you can select all your music and right click. Select the add to sync tab. Then on the right side of your screen the music will show up. Then you click the sync tab and Windows Media Player will sync your music from your samsung to your computer.
Transfer songs from my mp3 to lap top
1. plug in
2. enter device via My Computer
3a(mtp mode).copy and paste from folder to desktop or another folder.
3b(USB mode). enter folder "MTP" and do step 3a.
