20 Most Recent
SIM2 C3X LINK DLP Projector Questions & Answers
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
Power fuse keeps blowing, as
There is most likely a short circuit in the power supply unit, or on the main processor board.
You would have to disconnect the cables running from the power supply to the other boards and gradually reconnect them until the problem shows up again. If you have the service manual you could follow the fault finding procedure, but would need to have a lot of experience in electronic fault finding and the correct test instruments.
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
