20 Most Recent Frigidaire 24 in. FDB635RF Built-in Dishwasher Questions & Answers
2answers
Frigidaire dishwasher stuck on heat dry
That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
1/12/2022 1:30:17 AM • Frigidaire 24... • Answered on Jan 12, 2022
2answers
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
6/12/2018 11:45:54 AM • Frigidaire 24... • Answered on Jun 12, 2018
Dishwasher won't go through cycle
Model number would help alot! to locate...Open your Frigidaire dishwasher's door and check the inner frame -- left top corner and the left and right sides --for the product label containing the model number. or Check the inside of the door frame if you don't find the number on the inner frame. let us know. thanks!
12/27/2017 7:01:56 PM • Frigidaire 24... • Answered on Dec 27, 2017
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
4/30/2015 4:26:10 PM • Frigidaire 24... • Answered on Apr 30, 2015
Why won't my upper arm spin?
Good Afternoon Friend, I understand that the upper arm is not spinning in your Frigidaire dishwasher, model# FDB635RF. First, check to make sure that your water pressure is between 30 and 120 PSI. If the water pressure is not good in the area your dishwasher is located, try not to use any other water in your home while using your dishwasher. Secondly, make sure that there are no tall dishes that could possibly be blocking the upper arm from spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful. -Best regards- WP
6/2/2014 5:10:48 PM • Frigidaire 24... • Answered on Jun 02, 2014
0answers
Door latch assembly
Good Morning Paula, I see that you are having trouble with your Frigidaire dishwasher, model # FDB635RF, not starting after you close the door. Might I suggest trying to give the appliance a hard reset. You will do this by shutting the power off at the circuit for at least 2-3 minutes. When the power is restored, if you are still having trouble with the dishwasher starting up, I would suggest contacting either the manufacturer, or your local authorized technician for further assistance. -Best Regards- WP
4/4/2014 12:24:11 PM • Frigidaire 24... • Answered on Apr 04, 2014
Fridgidaire FDB4050lhb1 restarts, stops, cycle problems
see the w. diagram, test for switch door2) if the switch is defective, the starting relais will be over and over.God bless you5_10_2012_10_36_39_am.gif5_10_2012_10_37_00_am.gif
3/22/2014 7:52:48 PM • Frigidaire 24... • Answered on Mar 22, 2014
0answers
No lights on
Be the first to answer 2/5/2014 12:36:34 PM • Frigidaire 24... • Posted on Feb 05, 2014Be the first to answer
0answers
Noisy Hoover hed6612 dishwasher
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
1/27/2014 10:17:18 PM • Frigidaire 24... • Answered on Jan 27, 2014
Dishwasher heating element won't turn off
Hello niki4god - I recommend resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the control board or a potential wiring failure.
6/20/2013 6:31:12 PM • Frigidaire 24... • Answered on Jun 20, 2013
2answers
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
7/27/2012 1:35:44 PM • Frigidaire 24... • Answered on Jul 27, 2012
Kitchen aid heating water
1) The heating elements +thermostat is the device for heating water. You must test this device in order to provide good clean dish. God bless you
5/9/2012 10:53:16 AM • Frigidaire 24... • Answered on May 09, 2012
My wife noticed there were smears on the
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
9/24/2011 6:51:07 PM • Frigidaire 24... • Answered on Sep 24, 2011
0answers
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
150 questions posted
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
frigidaire dishwasher stuck heat dry
  • Dishwashers
