20 Most Recent
MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker Questions & Answers
Ford code
this is the same model that i was asked about earlier. i cant do anything about this though. only ford can help you with this. thanks for asking though.
8/16/2014 4:41:34 AM •
MTX Ford...
Answered
on Aug 16, 2014
Radio code required
i suggest you contact ford about this. i cant seem to locate either of the codes for this model. sorry for the delay.
8/25/2013 8:05:44 AM •
MTX Ford...
Answered
on Aug 25, 2013
2004 mercury mountaineer door ajar light
Ends up being a broken wire(ground) in the rubber boot between door and frame. I carefullly removed door panel, pinched the ends of the boot and slid it back into door. And there it was...a broken black wire. Spliced in a new piece of wire, reassembled everything else. Everything works like it should. It's really not that hard just take your time. Also before I started I disconnected the battery as a precaution. Goodluck.
5/26/2013 4:30:11 PM •
MTX Ford...
Answered
on May 26, 2013
98 explorer 4.0 missfireing and rough idle 147000
Check/change the #4 plug. Make sure the gap is right, ceramic not broken, and that the plug wire is on correctly.(both ends) Did you use dielectric gel when you installed the plugs? Good idea to use it.
4/2/2010 8:10:14 AM •
MTX Ford...
Answered
on Apr 02, 2010
Door Ajar Light
the switches for these vehicles are in the latch and they seize up from time to time. you will have to spray some penetrating oil into the dor and rapidly close and open the door hard to try and fix it. if that doesn't work then you will have to figure out which door it is and replace to latch. note if key is on, the dash will make a tone everytime you open and close door. so the door that doesn't chime that is the door with the issue.
8/28/2009 12:58:52 PM •
MTX Ford...
Answered
on Aug 28, 2009
