20 Most Recent HP Pavilion Elite M9150F Desktop PC Questions & Answers
Boot Path Issue? HP m9150f 3rd failed hard drive
You may need to flash the BIOS to correct this problem. If your "Failed" drives can be "seen" and you can identify files on them, the problem is likely not the HDD but a problem in BIOS regarding a corruption of the BIOS itself. This should be looked at by someone familiar with the BIOS setup for your machine, and they need to look for the Boot Path order to see if it makes sense. This is not a disk issue from the description you gave, and should be correctible by renewing the BIOS program in NVRAM on the system board. A qualified tech should do this job unless you know someone who is familiar with this level of computer technology. My guess is you have no one who you know that can diagnose this problem and correct it that you know, otherwise you would not be posting this question. You can download the BIOS file from HP for that specific model, and put it on a USB drive that is bootable, and then refresh the BIOS yourself but I am assuming you have no experience in doing this, so your best bet is to take the failed drive/s and the computer to a tech and have them determine the exact issue and resolution. That has to be less expensive than buying hard drives annually, perhaps a different solution will be better than the ones you have already tried. If your PC is able to use a solid state drive you may want to consider this option instead of a traditional HDD.
12/4/2017 7:52:18 PM • HP Pavilion... • Answered on Dec 04, 2017
I want to replace/install 1.5TB drive in HP Elite Desktop, HOW?
no OS stated. if it was working now, we'd not do any of that, take no data risk. why risk it? we'd build new machine, and the clone it over. (all the ways ,lots) then you unplug this old dog and put the new one online. after testing it fully, sure. that gets ride of the hate stuff, no? doing it right? no idea at all the system usage on a DOMAIN at work or a server behind a fire wall or a server to the web with web content? a gaming server at home a video server at home. or?????? i can go here like 100 pages of ideas..... seems to me that be first to know. or just a account payable server in Finance office. answer 2. that raid controller must be learned. did you read the full book on it yet that be first first if doing this the hard way. all such controllers have there own set of rules. some are very smart can just plug in a drive and it syncs. then add or replace more, slowly and with monitors running from HP to make sure its ok as you go. Like done on huge proliant servers. question 1 who's RAID is it MS pure software raid (sux) on board STAT raid chip of some kind. (no full service tag shown) or adding major top raid controller, (best of best this is) ?????????????????? if i search HP.com for your DT, puter is a dead product. so can not read you manual for you, https://support.hp.com/us-en/product/HP-Pavilion-Elite-m9000-Desktop-PC-series/3644723/model/3644724/ the word raid is missing in all manuals there. so I must be using the wrong model number try going to HP.com the tell HP your full tag data, and then see if its the model with RAID< if yes,the books now match your rig. then read the manual on the rules for RAID i bet you they SUX. most do on cheap raid controllers. its not high end and is the pathway to H3LL of you guess. best i can find is not at HP but the chip it has, Intel ICH9R id talk the these guys on that, https://communities.intel.com/thread/48046 the limits are in the HP BIOS rom too. more links, gee ask HP.cOM forum>? http://h20564.www2.hp.com/hpsc/swd/public/detail?swItemId=vc_73576_2 here is a web search https://duckduckgo.com/?q=HP+RAID+ich9r++setup+rules&t=ffnt&ia=web
4/9/2017 7:07:55 PM • HP Pavilion... • Answered on Apr 09, 2017
How do I reset the wireless settings to my network
Log on to the router's local site and reset the settings.
10/22/2014 9:12:38 AM • HP Pavilion... • Answered on Oct 22, 2014
Upgrade cpu HP pavillion m1950f
http://www.hardwaresecrets.com/article/How-to-Upgrade-Your-CPU/427
10/22/2014 9:09:57 AM • HP Pavilion... • Answered on Oct 22, 2014
Card reader not working
Mostly the problem might be with VIRUS in side the system or Diod or Capacitor may opened forever on the integrated board. Check once.
10/22/2014 9:05:14 AM • HP Pavilion... • Answered on Oct 22, 2014
Network card
check with your vendor/ reseller if its under warrenty
9/12/2014 10:18:51 AM • HP Pavilion... • Answered on Sep 12, 2014
Installing Gigabit network card
Open your PC cabinet and install the network card in a PCI slot on your PC's motherboard.
9/12/2014 10:17:51 AM • HP Pavilion... • Answered on Sep 12, 2014
Replace two hard drives in a hp 9150 with one hard drive?
just move everything from one hd to the other hd. copy/ paste pics and whatever you want to save. then unplug that hd. I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
8/4/2014 1:45:00 AM • HP Pavilion... • Answered on Aug 04, 2014
REPLACING HP PAVILLION ELITE E210Y HARD DRIVE WITH 2 TB HARDDRIVE CAN i DO THIS?
Yes you can, for hard drives larger than 2TB you will need a 64 bit operational system like Windows 7, XP recognizes hard drives up to 2TB.
7/20/2014 4:32:33 PM • HP Pavilion... • Answered on Jul 20, 2014
Computer unexpectedly reboots
There could be a number of things wrong with the system that would cause it to randomly reboot. 1. Try an antivirus scan. Use a good, trustworthy antivirus software to scan for viruses. There are good, free software programs out there such as Avast! Free, Avira Free and AVG Free, if you don't already have an antivirus. 2. Is the computer overheating? Check to make sure your rear vents on the computer are not blocked or obstructed. If you aren't scared to open up the case, check to make sure it isn't clogged with dust. You could also try to check for faulty cooling fans inside the system. 3. Is there a problem with Windows? Have you made any changes to Windows recently? You can try a system restore, defragmenting the disk or running a disk cleanup.
1/17/2014 7:19:27 PM • HP Pavilion... • Answered on Jan 17, 2014
Fix registry for my CD-Rom driver
what are the problem moore exately.
4/5/2013 12:26:15 AM • HP Pavilion... • Answered on Apr 05, 2013
WHY IS MY HP PAVILLION 9150 ELITE TURNING ON AND OFF
may be over heating bad power supply the list goes on
1/29/2013 6:02:24 PM • HP Pavilion... • Answered on Jan 29, 2013
Hp pavillion m9405f
You need a Windows DVD -- Same version as you have -- Vista / Win 7, 32-bit / 64-bit.A local PC repair should be able to burn you a copy for a small fee.http://fixitwizkid.com/threads/how-to-fix-bootmgr-is-missing-in-windows-vista-7.6234/ Bypass "step 1" and follow the instructions for "step 2".Tallon41
9/17/2012 11:05:13 PM • HP Pavilion... • Answered on Sep 17, 2012
My BD-ROM drive doesn't seem to be working?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problemIt could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
9/10/2012 11:28:09 PM • HP Pavilion... • Answered on Sep 10, 2012
My PC does not start,
(Copyand paste to browser) If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting our customers free of charge... Thank you for usingFIXYA! Best regards,
Junior
9/16/2011 12:43:07 PM • HP Pavilion... • Answered on Sep 16, 2011
My Hp Pavilion Elite M9580a wont turn on. power
I recommend going through my guide it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
To me, off the bat, it sounds like a dead computer mainboard. However only purchase a replacement component when you know for sure which component it is.
12/21/2010 10:24:40 AM • HP Pavilion... • Answered on Dec 21, 2010
HP Pavilion Elite M9150F Desktop PC Logo
Popular Tags
34 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
want replace install 1 5tb drive in hp
  • Computers & Internet
