20 Most Recent Nortel Meridian M7208 Corded Phone Questions & Answers
Access Denied
Dear joanmyers,
You may want to try the CONFIG mode to change the time. Press Feature **266344 and depending on they version of the software (i.e, DR5) you may be able to change the time in the system configuration.
11/7/2022 3:25:34 PM • Nortel Meridian... • Answered on Nov 07, 2022
Meridian phone won't hang up.
Check the handset cable and make sure it is not plugged into the headset port. You should also try picking up the handset while on a call, make sure your HF button is not lit, wait a couple of seconds, then hang up the handset. If that doesn't work, then you should try looking in programming to see if there is a problem there.
6/1/2020 1:33:10 PM • Nortel Meridian... • Answered on Jun 01, 2020
Nortel Meridian M7208 page not working...
Press Feature * 3 press the 5th line key you want to use for paging enter the page-all code (feature 601-603 as you wish)
10/12/2017 2:08:31 PM • Nortel Meridian... • Answered on Oct 12, 2017
1 of four extensions is intermittently dead. Where do I start looking to fix the problem?
This is interesting. You need to consider things that change during the day. There is a demark point that the phone system connects to. This point may be in a closet etc. What environmental changes are happening near that point> Temperature, humidity, other devices coming on that send out interference etc.
1/24/2017 6:24:12 PM • Nortel Meridian... • Answered on Jan 24, 2017
The phone display window is blank but the phone works any suggestions for turing that on?
your phone's LCD display is defective and it should be changed. I have a similar problem but till it works that way, I can live with it. Actually I have 3 more with good display - hehe....If annoys you, get a used one from Amazon for 44 USDhttp://www.amazon.com/Nortel-Meridian-M7208-Telephone-Gray/dp/B0018JVOP2Sending it to repair might cost you more.
11/24/2015 4:11:56 PM • Nortel Meridian... • Answered on Nov 24, 2015
Ringer troubleshoot
Is it programmed to ring in configuration programming
8/20/2015 12:28:08 AM • Nortel Meridian... • Answered on Aug 20, 2015
0answers
2answers
How to program speed dial on t7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
4/18/2015 1:58:04 AM • Nortel Meridian... • Answered on Apr 18, 2015
How do I unlock mailbox locked
Feature 983 Password: 1020000 Mbox: Enter the mailbox number that is locked Press Reset after Password displays Password will now be 0000.
2/6/2015 5:22:47 PM • Nortel Meridian... • Answered on Feb 06, 2015
Cancel call forward
Feature # 4 F4 forward to: F#4 cancel forward
2/2/2015 8:50:05 PM • Nortel Meridian... • Answered on Feb 02, 2015
HOW CAN I TURN UP THE VOLUME ON HANDSET. VOLUME IS SO LOW CALLERS CAN NO HEAR ME
There is no outgoing (microphone) volume control, if it is only your set try the handset from different extension. The microphone element may have been damaged (especially if dropped) and have to be replaced. Replacement handsets are not hard to find. If everyone on your system claims that callers cannot hear them, there are some settings on the central switch (KSU) which might help, but only after ruling out a problem on your particular set.
2/2/2015 8:35:21 PM • Nortel Meridian... • Answered on Feb 02, 2015
My hansfree is not working
It may be programmed not to work. See your office mgr.
1/26/2015 6:34:00 PM • Nortel Meridian... • Answered on Jan 26, 2015
Nortel Meridian M7208 Corded Phone Logo
161 questions posted
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Nortel Lands Phones
  • Nortel Lands Phones
Most Popular Question
our phones working fine without incident
  • Lands Phones
