20 Most Recent Brother MFC-9440CN Laser Printer Questions & Answers
3answers
My brother mfc 9440 CN displays error code 32 and
you might try this video
2/11/2021 5:57:09 PM • Brother... • Answered on Feb 11, 2021
2answers
Brother9440 black dots appearing in line close to middle
it is problem drum spot open ypur printer drum unite and chack it or buy new one
8/23/2019 5:06:02 AM • Brother... • Answered on Aug 23, 2019
2answers
I just replaced the fuser on my brother mfc 9440cn
Try the instructions in this video. Your printer has a similar control panel as those specified in the video.
10/30/2018 9:27:54 PM • Brother... • Answered on Oct 30, 2018
2answers
How do i reset my toner it's not out of toner
Hello Thewwrental,
From the image I assume you are using a MFC-9440CN, 9450CDN or a MFC9840CDW.
In any of these cases, you can reset the toner cartridge by opening the fron cover and pressing the "clear/back" button.
You will be asked to select which cartridge you want to reset.
This will not work if the toner cartridge is actually empty.
Keep in mind that if one or more of the color toners are empty, you can still print in black and white by switching the drivers to mono.
Thanks,
Pat
12/11/2017 4:53:41 PM • Brother... • Answered on Dec 11, 2017
Dear Sir, We have Brother printer
check out these solutions for the same problem Brother MFC 9449CN CC3 205 03031f04 error message Scanner is unable to...
11/4/2017 11:04:51 AM • Brother... • Answered on Nov 04, 2017
0answers
How to a replace the motherboard on a Brother MFC-9440CN Laser Printer?
I spend a few minutes on google and quickly found a place that provides service manuals for brother printers. I suggest you do some research like this on google and you tube and you will find your answer there.
7/5/2017 6:03:44 AM • Brother... • Answered on Jul 05, 2017
How to remove shadow on prints - Brother MFC-9840CDW
Call on Brother technical support number 1-800-243-0019 Toll free. And get Instant support for your Brother Printer from our Brother tech support team?
4/14/2017 11:30:25 AM • Brother... • Answered on Apr 14, 2017
Replace drum, still says replace the drum and now it won't print.
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
(if you did the reset, you may need to talk to Brother Support. I'm assuming you used a Brother drum and only handled it by the handles.)
3/4/2016 7:32:51 PM • Brother... • Answered on Mar 04, 2016
0answers
0answers
CANNOT GET OCR FEATURE TO WORK ON BROTHER 9440CN
Yiou need to use ScanSoft Paperport OCR software.
12/5/2015 8:00:48 AM • Brother... • Answered on Dec 05, 2015
My printer Brother MFC-9440CN is unable to print.
Hi there !
I am here to help you to solve your problem.
I believe your print spooler service stop running or your spooler is confused pending some queue at the print spooler service.
To resolve this, follow this procedures.
Go to START MENU
Choose RUN (For Windows XP) or Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
7/23/2015 2:16:34 AM • Brother... • Answered on Jul 23, 2015
I am unable to print getting 2 A troubleshootingm and routine maintenance
A combination of key press and powering-on should clear the error log which will let your printer work normally
6/22/2015 1:35:02 PM • Brother... • Answered on Jun 22, 2015
2answers
Drum Ends Soon
you need to replace the drumkit, or have it replaced.
3/21/2015 11:07:22 PM • Brother... • Answered on Mar 21, 2015
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
http://www.laserquipt.com/support/idx/26/452/article/Toner-Smearing-Issues.html
3/21/2015 11:05:46 PM • Brother... • Answered on Mar 21, 2015
Brother MFC-9440CN Laser Printer Logo
439 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
samsung scx 4729fw replace toner
  • Office Equipment & Supplies
