20 Most Recent HP LaserJet M1005 Printer Questions & Answers
3answers
How to disable copy in HP Laserjet M 1005 MFP
I will say for me, i would rather uninstall then reinstall with the installation disk where during the installation process you will have options to select the functions you want to install.
11/30/2022 8:20:57 AM • HP LaserJet... • Answered on Nov 30, 2022
Scanner error 16, HP MF1005
my printer hp laser jet 1005 showing scanner error 16 please gave me solution
10/17/2022 4:57:51 AM • HP LaserJet... • Answered on Oct 17, 2022
2answers
Code Error B0605
B0605 message. Follow HP's directions at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01687323&lang=en&cc=us&conte... and put the printer in BootCode mode then ran the firmware updater. The directions indicated that the printer would restart on it's own, but if does not, so let the printer sit for about a minute after the Firmware Updater says it was done, then power down the printer and pull out it's power cord. Let it sit for about 15 seconds, then plug it back in and start it up. When the printer starts up, the printer's display may go through a bunch of messages (Erasing...) for a few seconds. When it finishes with all of the messages, you should be able to print to the printer again. I hope this helps. Regards, Mike
2/2/2022 6:29:09 PM • HP LaserJet... • Answered on Feb 02, 2022
Please load requested paper in the tray or press the GO button at the device to use the available paper
Something you have printed is asking for a non-standard paper. I have seen quite a few cases where PDF files are defaulted A4 not letter and this causes this error all the time.
7/29/2021 8:59:53 AM • HP LaserJet... • Answered on Jul 29, 2021
50.0 fuser error hp mfp1005
Fuser faulty, replace it....
7/29/2021 6:43:22 AM • HP LaserJet... • Answered on Jul 29, 2021
2answers
Why is there permanent storage init error?
web search HP laserjet printer error codes
7/28/2021 6:18:11 AM • HP LaserJet... • Answered on Jul 28, 2021
How to solution scanner error 17 in hp m1005
HP LaserJet M1005 Mfp driver pls check the scaner lamp is moving or not i f not pls replace the scanner cable
7/26/2021 6:10:48 AM • HP LaserJet... • Answered on Jul 26, 2021
2answers
HP LaserJet M1005 scanner M1005 mfp how to share beware spam number 1*800*532*4187
Hi ,Ok , 1st - lets go to your control panel , and click on printer and devices ,see if your other printer is there , if not you need to add a printer , make sure your other printer is turned on , now is this a wireless printer or cable connection ?if it is wireless answer yes when ask , if not say cable , once the printer is added you should be able to share your printer ........let me know if this works , if not I will advise futher ..............Good luck Roy
3/7/2021 9:00:32 AM • HP LaserJet... • Answered on Mar 07, 2021
4answers
Hp M1005 Laser printer showing no print cartridge ...
hi
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
7/4/2019 3:41:30 AM • HP LaserJet... • Answered on Jul 04, 2019
Hp lj m1005 scanner error 6
Scan head faulty & it need to replace to solve this issue...Scan head located under flat bed glass, to remove this part flat bed unit need to open..see the snap shot.5_25_2012_7_09_54_pm.jpg
6/2/2019 7:04:48 AM • HP LaserJet... • Answered on Jun 02, 2019
3answers
I have a lj m1005
hewlett_paokard error:B0601
2/25/2019 3:37:53 AM • HP LaserJet... • Answered on Feb 25, 2019
Scanner error 20
1, The Scanner error 20 is because of insufficient memory in the printer. This problem occurs when the printer prints more complex documents that exceed the capacity of the printer. 2, When you press the GO button, the printer will print the document, but the data may be missed and skewed. You can solve adding more memory to the printer. 3, This error may also occur because of mismatch driver software. So, uninstall the driver software of the printer. Restart the printer and install the full-featured driver software. 4, You can download the driver software from the 123hp.co link. The link provides the printer driver software that is compatible with the operating system and version of your computer or laptop. 5, If the problem continues, simplify the print job and print documents which do not exceed the memory of the HP Laserjet M1005 printer. For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
10/12/2018 11:05:58 AM • HP LaserJet... • Answered on Oct 12, 2018
Load tray 1 press GO
1, Read the specification document and learn what the paper sizes are compatible with the printer. Load the papers and adjust them using the paper width guides. 2, Make sure you are using appropriate paper type, for example, if you are printing a photo, load the photo sheets into the input tray. 3, Also, make sure, you mention the right paper settings in the Printer Settings page. By following the guidelines, you can avoid this issue. For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
10/12/2018 11:05:02 AM • HP LaserJet... • Answered on Oct 12, 2018
How to open rear access door
1, To clear the paper jam issue at the rear of the printer, perform the printer reset to resolve the issue in a simple way. 2, To reset the printer, remove the papers from the input tray while the printer is turned on. Unplug your printer's power cord from the rear of the printer. 3, Now open the cartridge access door and check if the carriage can move freely along the paper width guide. Look for the jammed paper and gently pull it out. If some paper bits are found inside the printer parts, try to remove them too. 4, You can now print a test page by pressing and holding the Cancel button along with the Resume button. The printer would have got reset, and the test print would have resulted well. 5, Even after resetting if the paper jam issue did not get resolved, better service the printer in the nearest HP retail stores. For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
10/12/2018 11:04:22 AM • HP LaserJet... • Answered on Oct 12, 2018
Scan multiple pages pdf
1, Double-click on the printer icon on your Desktop and select the Scan a Document or Photo option from it. Lift the Scanner lid and place the first page with scan side facing down. 2, Check the scan settings and click Scan document to file. Click the Scan button, and the scan process will begin. Now remove the first page and replace the second page on the scanner glass. Click on the "+" sign located at the left-hand side of the display. 3, In the same way, continue scanning other pages too. Once you completed scanning all the pages, click Done after saving the file with a file name. 4, You can change the destination name in the printer settings. In this way, multiple pages can be scanned as PDF. For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
10/12/2018 11:03:48 AM • HP LaserJet... • Answered on Oct 12, 2018
2answers
My printer hp m1005 has no print then shows device error
Need more details. what are the error codes or errors indicated on the screen?
10/8/2018 2:28:03 AM • HP LaserJet... • Answered on Oct 08, 2018
Hp laserjet m1005 scaner error 20
Scan head drive mechanism faulty., Follow the snaps chk for breakages., Replace new part if its available, If not alter the part as shown in snaps..( ex:which I did early) 25484620-qzayjjyinm5jkjjexvgskf3e-1-0.jpg 25484620-qzayjjyinm5jkjjexvgskf3e-1-2.jpg 25484620-qzayjjyinm5jkjjexvgskf3e-1-5.jpg 25484620-qzayjjyinm5jkjjexvgskf3e-1-9.jpg
9/6/2018 5:22:49 PM • HP LaserJet... • Answered on Sep 06, 2018
Hp leserjet printer error.
Service-mode functions NVRAM initialization An NVRAM initialization will return the following device settings to the factory-set defaults: ? All menu settings, including the fax header and company name ? Fax numbers and names that are associated with one-touch keys and speed-dial codes Additionally, all faxes stored in memory are cleared. Perform an NVRAM initialization 1. Turn off the product. 2. Simultaneously press and hold the the product. 3. Wait until the message Permanent storage init. appears, and then release the arrow buttons. When the NVRAM initialization process has been completed, the device control panel shows the Ready message. Super NVRAM initialization A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic product mode). NOTE: When the product is turned on, you will be prompted to select the language and country/region setting before the product will initialize. 1. Turn off the product. 2. Simultaneously press and hold the the product. 3. Wait until the message Permanent storage init. appears, and then release the arrow buttons. Service menu NOTE: An asterisk (*) symbol next to a service submenu option indicates that this is the current setting for that option. For more information about using the service menu, see Access the service menu 1. Press the 2. Use the arrow buttons to select Main Menu Service, and then press OK. 3. Use the arrow buttons to select the desired secondary-service option, and then press the button. 4. Use the arrow buttons to select the desired submenu option, and then press ENWW Setup button. Cancel button and the right arrow button Cancel button and the left arrow button Service menu on page (> ), and then turn on Cancel and right (< ), and then turn on Cancel and left 241. OK OK directly from service manual
6/11/2018 4:43:20 AM • HP LaserJet... • Answered on Jun 11, 2018
Scanner error 14
I just re-read one of the earlier posts on a similar problem and noticed the HP Expert suggestion to run CCleaner as part of getting the software cleaned up.
5/31/2018 6:25:41 AM • HP LaserJet... • Answered on May 31, 2018
HP LaserJet M1005 Printer Logo
379 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
laserjet m1005 printer hp m1005 laser pr
  • Office Equipment & Supplies
